E60 525i Right Rear rubbing/grinding/clunk Sound HELP :)
Old 04-04-2014 | 05:48 PM
djreese's Avatar
My Ride: E60 Black Saphire, sport, logic 7, nav, 15% tint,
Unhappy E60 525i Right Rear rubbing/grinding/clunk Sound HELP :)
Been searching the forums with not much luck other then the M5 board, I keep getting a rubbing/clunk sound out of my right rear if I go over a larger bump in the road or make a sharp right turn. I just had a lower control arms replaced in the rear along with an alignment which were bad and I thought was the problem. Well I still have it, I do have aftermarket rims F10 M5 19" rims and I do have sport suspension. My rear tires are 285/35/R19 when my mechanic looked at it, I also searched for forums for about 2 months before I got my tires and many people said they had that size tire in the rear with no problem, and I also say a 528 with 166's with same tire side in person at the stealership but my mechanic looked at it and said no sign of rubbing or tire wear so im kind of lost. Many M5's are experiencing this problem and they are saying replace the rear differential oil, well M cars have an LSD and regular E60's have bmw open differential. They are saying replace it with
BMW part # 83-22-2-282-583
SAF-XJ with FM Booster on it.
Can I use this with an bmw open differential? Any suggestions would help or input im kind of lost.
Also one guy on the forums said he had a problem and it was his right rear sway bar link and that fixed his problem.
I dont want to take a girl out and my car sounds like its falling apart lol
PLEASE HELP ME
-Reese
Old 04-07-2014 | 01:16 AM
rorschach76's Avatar
My Ride: 535xit
Model Year: 08
Bump for answers to my similar problem.
Old 04-07-2014 | 10:00 AM
djreese's Avatar
I know bro almost 100 views and no answers lol I just need some guidance
Old 04-08-2014 | 02:45 PM
3xv's Avatar
3xv
My Ride: 2007 530i
I recently took ownership of a 2007 530i Mid march of this year with 77600mi. and I too heard a "clunk" intermittently after a week of driving it to work.
I have replaced the rear diff. oil and have not heard the clunk since. I'm not sure if that was the cause or it just resolved itself but diff oil change is fairly easy and inexpensive. I used Redline 75W90 Diff oil for $18/L bottle (you will need 2 bottles). It's worth a try and the very least is that your car gets new diff fluid and at the same time you will be able to eliminate that as a source of your issue.......Good luck
Old 04-08-2014 | 05:58 PM
djreese's Avatar
I hear redline is great just not many post that resolves the issue but im happy that fixed yours a lot of people are saying the
but thats $60L
so i would be down to use redline just any other inputs on this?
socale39
09-05-2023 09:30 AM
tom333
03-20-2015 01:30 PM
ZeZe
10-15-2003 01:58 PM
08-12-2003 12:41 PM
06-17-2003 10:38 PM
Quick Reply: E60 525i Right Rear rubbing/grinding/clunk Sound HELP :)
