E60 525i 2005 fog light changing help
Hi, i wanted to change the fog light bulb, however i have found out that the left hand side and right hand side are different, on the left hand side ( passenger side) got the windscreen water tank in the front of it. does anyone know how to change it ?
thanks alot
Mike
thanks alot
Mike
There are a few DIY's on this board on how to change it. The fog light procedure is still the same, it is just that on the left hand side there is a water tank and it is a lot harder to reach the fog light bulb. You just need to fit your hand in on the left hand side of the water tank (if you have relatively small hands). The first time I switched out my fog lights I did it via the wheel well, however if I would do it again I would just remove the headlights and simply reach down to switch out the fogs.
Here is a DIY in case you want to remove your headlights:
https://5series.net/forums/topic/830...headlamps-diy/
Here is a fog light DIY using the wheel well method:
https://5series.net/forums/topic/591...light-install/
tjackson9810
04-21-2015 07:42 PM
linxuan
E39 Discussion
03-22-2015 06:16 AM
