E 60 528 xi 2008 Cranks but won't start - Strange
#21
My Ride: 2008 528 xi
Don't be overly consurned with 15.3v with the extremely cold temperatures you have been experiencing. The IBIS and the balance of the charging system is temperature compensating, ie the colder it gets, the higher the voltage to a point. 15.8-9v range tops. The same with summertime high temperatures, may only be 13.2v or so with engine running on a hot August afternoon.
Thanks
#22
My statement of owning the 2008 BMW 528 xi for 6 mos should be more accurately stated at 11 mos. Almost a year, which could be the amount of time it might take to eventually wear down a good AGM battery by overcharging. However at this points its a possible clue as to what might be wrong with this car.
You bring up a good point , does any one have a good handle on the detailed distinction between registering and reprogramming modules when it comes to battery changes? Can it be done with INPA? I must be a real moron because the I can not fully understand some of the threads on this site. The "Idiots guide to INPA helps but some general summary type info is missing.
thanks
thanks
http://www.xoutpost.com/attachments/...ration-diy.pdf
#23
Here is the document I used to register the battery the last time. It also includes instructions for changing the battery type or battery capacity.
thanks
#24
#25
#27
My Ride: 2008 528xi black
Hey, Just wanted to say I'm having the same problems. 2008 528xi , crank no start but second time i try it turns on with a rough idle. I took it to the shop they said its the Crank Sensor. I dropped it off today and got a call saying my Harmonic balance has a wobble and is causing a nasty squeal. they want 300 for the sensor fixed and 700 for the Harmonic Balance.
#28
Try this document "Energy Management"...
http://www.bimmerfest.com/forums/att...3&d=1420343442
Not the one I was looking for but a good starting point.
#29
If you have INPA running already, the software you installed probably has the others as well. If not, do some searching for INPA cables and software. I got my OBD K+DCAN cable off ebay. Make sure you don't just get a K-only cable. Most all the downloads I've seen have NCS Expert and Tool32 included.
#30
Most of the loads i see which are capable of being shut down are communication related and not start related. Am I reading this right?
Another intesesting point in this document seams to indicate that the maximum charging voltage is 14.8V. Mine is at 15.3V, after a full charge at 34 deg. There should be no reason to overcharge.
Here again, the only thing that makes sense to me, is the CAS was not coded correctly for the AGM battery?
Does anyone know what the ah ( amp/hours) for the original battery for this car would have been?
