Dustless brake pads for a 535xi?
Old 05-22-2016, 10:41 PM
illogic847's Avatar
My Ride: 2008 535xi
Default Dustless brake pads for a 535xi?
Wondering if someone could suggest some good dustless brake pads.
The amount of dust the stock pads produce is getting to be a really big pain.
Thanks in advance
Old 05-23-2016, 03:48 AM
Administrator
JayArras's Avatar
My Ride: 530xi
Engine: N52
Akebono ceramic pads
Old 05-23-2016, 04:46 AM
jtbgonesailing's Avatar
My Ride: e60 530i e21 320i
Model Year: 2005 1981
Engine: M54 M10
+1 on Akebono pads...
Old 05-23-2016, 05:59 AM
BostonJon's Avatar
My Ride: BMW 530xiT (E61)
just replaced my OEM pads with akebono euros (ceramic) last week at the recommendation of Jay and others on the board. I washed my wheels the day I put them on (saturday the 14th) and as of yesterday they still look perfectly clean.
from recent experience, you should expect less initial bite when you switch to ceramic but you will get used to it quickly.
i ordered them from amazon ($67) and i know i ordered the right part number (EUR918), but i think they shipped me EUR918 because there were metal clips on the pads for the non-piston (outboard) side. in order for the caliper to fit over the new pads and attach to the caliper bracket, I had to dremel off the clips on that side. i think those extra clips are needed for the 3-series application. it only took a few min to get the clips off but I was agitated that the wrong set was sent. make sure you get the right set - the inner pad should have three clips on the backside to fit into the piston bore. the outer pad should have a smooth back with no clips.
Don't forget to get a new wear sensor. i know some people reuse them but mine was stuck in there and I couldn't get it out without breaking it. you can find them for around $15.
Old 05-23-2016, 11:26 AM
illogic847's Avatar
My Ride: 2008 535xi
Thanks for the replies. I found the EUR918 on Amazon. Does anyone know if those are the correct ones?
Old 05-23-2016, 11:35 AM
BostonJon's Avatar
the EUR918 are standard for most non-M 5 series across quite a few years.
dont believe me? use their catalog
Akebono Brakes Online Parts Catalog
Old 05-23-2016, 11:39 AM
BostonJon's Avatar
see list here
Attached Thumbnails Dustless brake pads for a 535xi?-2016-05-23-15_37_48-akebono-brakes-online-parts-catalog.jpg
Old 05-23-2016, 12:27 PM
insyder's Avatar
My Ride: '98 Lexus GS300 Prev Ride: '07: 550i
I did Brembo ceramics and am very happy with them.
Old 05-23-2016, 12:34 PM
BostonJon's Avatar
this was initially going to be my first choice until i switched to akebono. the brembos are also available on amazon for about $65 IIRC - and that includes the sensor.
Old 05-23-2016, 09:43 PM
illogic847's Avatar
My Ride: 2008 535xi
Thanks for all the heads up guys
Quick Reply: Dustless brake pads for a 535xi?
