DSC Malfunction
Old Dec 7, 2016 | 12:20 AM
hardjasaputra's Avatar
My Ride: E60 520i with M-bodykit
Engine: M54
Question DSC Malfunction
Friends,
I recently purchased an '04 E60 520i with M54 engine.
When I drive the car sometimes the DSC warning popped out (the yellow triangle with the counterclockwise arrow sign) and the iDrive display ".....bla bla bla...drive moderately".
When I turn off the engine and re-started everything got back to normal. I read around and got idea that the steering wheel sensor might be at fault here. Have you guys have any experience with this problem? what should I check?
Old Dec 7, 2016 | 01:31 AM
DanielFD's Avatar
My Ride: 2007 BMW 550i
Sounds possible but you cant be 100% sure without getting some codes pulled.
Old Dec 7, 2016 | 02:44 AM
KyleB's Avatar
My Ride: 530i
Engine: M54
you need to retrieve fault codes, preferably using a BMW specific tool, then come back and post what they are. your problem could be anything from a wheel speed sensor to a steering angle sensor. impossible to diagnose without fault codes.
Old Dec 7, 2016 | 09:17 PM
Engine: M54
Thanks so much for the info.
The warning only comes out occasionally. Would the fault code come out when there is no warning? Or should I wait until the warning come out and have the car scanned?
Old Dec 8, 2016 | 02:19 PM
dakest's Avatar
My Ride: 530i base model
Happens to me also, if your signal light doesn't return and stays on the position you're turning is very likely the steering angle sensor.
I read some where here that you can clean it, I haven't done it since it stops popping up for a long while.
Old Dec 9, 2016 | 11:24 PM
DanielFD's Avatar
No need, the fault code is stored when it happens the first time.
Old Dec 13, 2016 | 12:28 PM
dakest's Avatar
Have you gotten the chance to read codes?
Old Dec 19, 2016 | 07:32 PM
Engine: M54
Sorry, I haven't got a chance to scan my car. I've been buried in my work, the before-Christmas-routine.
Hopefully I will have a chance during or after this holiday.
Old Dec 19, 2016 | 07:36 PM
Engine: M54
In my case, the turning signal still works normal. It goes off when it's suppose to.
Old Mar 19, 2019 | 06:25 PM
Engine: M54
I finally have a chance to get the error codes: it said 28AE "Torque Limitation: Monitoring" .
