DSC DTC and Standing Lamps
My Ride: Now Driving a Freakin' Prius!
Was...
2004 545i | SMG | White/Black | Sport | NAV | Logic 7 | PDC | Fold-down Seats | Adaptive Headlights | Cold Weather Pkg | Clear-again Bra | Mud Flaps | Bluetooth | Coat Hangar | Aux Input | All Weather Mats | 18"X8.5" BBS RK w/ Michelin Pilot Alpin's (winter) | New steering rack @ 1.2K & 17K miles| Software V.19.1 | B&B Exhaust (vrrrroooooommm!) <---Click.
Hey Rudy,
Thanks for the multiple quotes tip.
The limited slip is really NOT that important considering that the electronics (when active) pretty much help. However, when playing around with Acceleration Assit (which is rather infrequent) it would be a nice thing to have. If I ever start taking my car on some road courses again it would also be nice. For 98% of the time, I'd say it really doesn't matter. But there is always that 2%.
And Yes, I do enjoy my car - I can't wipe the stupid smile off of my face whenever I'm driving it. It is by far the best car I've owned (OK, leased... whatever).
I guess I was/am just letting the other members (who may care) know that there is no limited slip.
BTW, 2 big black strips are much better than one .
My Ride: G30 M550i
Model Year: 2018
Gotcha.
You must have stock in Bridgestone, Dunlop, Michelin, etc. I have enough trouble getting the tires to last without intentionally tearing them up!
As far as the torque, I don't think there's more of it, it's just distributed more evenly across two wheels instead of one, right?
My Ride: F02 LCI Individual
Model Year: 2013
Originally Posted by realtyman' date='Sep 30 2004, 06:03 AM
I think you mean Wheel, not wheels.
I have yet to get more than one wheel to spin.
Unless one can get Both wheels spinning, your break out/oversteer just 'aint gonna happen!
[snapback]39571[/snapback]
Actually I meant wheels, because if you are on an even surface and the car and the steering wheel are straightened out you can get both wheels to spin. In that case, yes, no oversteering! But usually you don't have an even surface and you're not straight, so the car oversteers and you only burn one tire...
Since you usually oversteer and burn one tire I wrote the warning... And if not, you're doing it perfectly right and then it is wheels!
Originally Posted by skipper' date='Sep 29 2004, 09:36 AM
[quote name='yogibear458' date='Sep 28 2004, 10:21 PM']AFter 1 week of ownership... I'm still puzzled with a couple things:
3.? pg 88 - Standing Lamps (left and right)
I played with this and the Pathway lighting.? I understand the Pathway lighting but disappointed that when I return and unlock the car, the Pathway lighting doesn't come on to greet me as my other cars do.
Any ideas, please?
Any ideas, please?
[snapback]39136[/snapback]
Hope this helps on the pathway lighting question.
[snapback]39217[/snapback]
[/quote]Actually, there are two "pathway lighting" functions: one is to turn on the headlights so you can see in front of the car, say to illuminate your driveway when walking to your house, which is switched on using the headlight flasher after the car is turned off (and it stays on for the set number of seconds in I-drive). Those lights do not come on again when returning to the car and unlocking it with the remote. The other lights are shining down from the side mirrors to illuminate where you step out of the car and come on when you open the door (presumably so you can see a big puddle that you don't want to step into). These lights also stay on for the set number of seconds, and they DO come on as well when remotely unlocking the car, so you again see where you step as you get in.
Originally Posted by PeterF' date='Oct 7 2004, 05:55 AM
Actually, there are two "pathway lighting" functions: one is to turn on the headlights so you can see in front of the car, say to illuminate your driveway when walking to your house, which is switched on using the headlight flasher after the car is turned off (and it stays on for the set number of seconds in I-drive). Those lights do not come on again when returning to the car and unlocking it with the remote.? The other lights are shining down from the side mirrors to illuminate where you step out of the car and come on when you open the door (presumably so you can see a big puddle that you don't want to step into). These lights also stay on for the set number of seconds, and they DO come on as well when remotely unlocking the car, so you again see where you step as you get in.
Model Year: 2013
Originally Posted by alohalc' date='Oct 7 2004, 11:17 PM
[quote name='PeterF' date='Oct 7 2004, 05:55 AM']Actually, there are two "pathway lighting" functions: one is to turn on the headlights so you can see in front of the car, say to illuminate your driveway when walking to your house, which is switched on using the headlight flasher after the car is turned off (and it stays on for the set number of seconds in I-drive). Those lights do not come on again when returning to the car and unlocking it with the remote.? The other lights are shining down from the side mirrors to illuminate where you step out of the car and come on when you open the door (presumably so you can see a big puddle that you don't want to step into). These lights also stay on for the set number of seconds, and they DO come on as well when remotely unlocking the car, so you again see where you step as you get in.
[snapback]42260[/snapback]
[/quote]Did youtried to pull the lever after the car was off? Then the lights should come on and stay for the set time...
[snapback]42269[/snapback]
Originally Posted by paasan' date='Oct 7 2004, 01:28 PM
You pull the lever to your left towards you, as if you were to flash your long dist. beams.
[snapback]42313[/snapback]
