Driving in 3rd gear.
When I am driving slow (stop and go traffic or around a parking lot) in often put it in manual mode and leave it in 3rd so the ride is smooth with no shifts. Is this bad for the transmission? Does it put too much strain on the transmission?
Thank you
-Krozi
Thank you
-Krozi
Your solution prevents the tranny from constantly shifting, so I wouldn't be concerned with the tranny; but, you probably don't want to run the engine much below 1,000 rpm. So keep an eye on the tach and downshift if the rpm gets too low.
Originally Posted by SilberGrauE60' post='798011' date='Feb 20 2009, 08:32 PM
The only problem with an auto tranny is when it is hunting for the right gear, constantly up- and down-shifting, because you are at a speed that is right on a boundary of a normal shift point. This effect is increased in hilly terrain. This can cause tranny overheating.
Seriously ... instead of going the Manual mode maybe moving to S will hold the gears longer and reduce the hunting when driving in hilly areas ??
Don't worry - with steptronic the car will not let you harm the transmission. If the RPM were to drop to a level that would create an issue, the car will downshift, even in manual mode.
If you were at low RPM in too high a gear you'd lug the engine and it would eventually stall. The step won't let any of that happen and it'll up or downshift as needed. The occasional stall isn't too bad for the engine but it's best avoided.
