5Series.net - Forums
-   -   Driver's Window Anti-Trap Malfunction (https://5series.net/forums/e60-discussion-2/drivers-window-anti-trap-malfunction-88070/)
jgbmw Oct 23, 2009 05:08 PM
Every so often my driver's window retracts after the auto-up function is activated. The only repeatable sequence this happens is that when the window is down and after I place the transmission in Park, then auto-up the window, it closes most of the way and then retracts back down. Only the driver's window does this and it doesn't happen every time. The only thing i can come up with is that the auto-trap function is not working properly. I've tried the auto reset procedure of continuously holding the up/down button on close and open.
Any suggestions?
eurotunerM3 Oct 23, 2009 06:53 PM
Mine did the same thing recently. I took it to the dealership and they said it was in fact a window anti-trap malfunction.
If you have CPO it will be covered under warranty for a mere $50 deductible.
550i-sport Oct 23, 2009 07:02 PM
Mine did that on the rear driver-side window - bang!. Take it to the dealer.
r9ndy Oct 23, 2009 09:01 PM
give this a try..
https://5series.net/forums/index.php?s=&amp...st&p=618509
Rudy Oct 24, 2009 04:12 AM
Don't go to the dealer, just take a look at the following thread -- be sure to read more than the first couple of posts since the instructions were refined over time:
https://5series.net/forums/index.php?showtopic=25812
jgbmw Oct 24, 2009 06:37 AM
Ok thanks. My auto-up/down feature works, so I believe there may be another malfunction. The issue that I'm having is that the window doesn't roll up in auto mode once in awhile...and there's is no error in iDrive.
Rudy Oct 24, 2009 06:48 AM
I still think the fix for your problem is the same...
porsche911targa Oct 24, 2009 07:16 AM
+1
