Driver Stability Code from Disconnecting
My Ride: 05 jet black 545i ya...
Dealership wanted $500 to replace window actuator and window track, so I took the door panel off and discovered nothing was wrong with the motor. The wire on the pulleys was all tangled. I fixed the issue and now that my battery is plugged back in I have a driver stability control code on. Any ideas on how to clear this? I tried searching but some random stuff was coming up.
Thanks guys
-Nick
Thanks guys
-Nick
My Ride: BMW
I've heard that can happen if the battery has been connected for an extended period. Turn the wheel all the way to the left, right, then left again. This should reset the steering angle sensor...somebody please confirm.
