driver side license plate light not working
Old 12-11-2014, 02:39 PM
teohenwhy's Avatar
My Ride: 528i
Model Year: 2010
Default driver side license plate light not working
My drivers side license plate has been out for some time now and I found that a couple wires were sliced and touching each other where it goes into the trunk hinge. Apparently this is a common issue. I repaired the wires and tested every fuse in the trunk and glove compartment but the light still isn't working. I know the bulb is good because I swapped it out with the passenger side license plate light and it's good. Are there more fuses somewhere else I need to check? I tested the wire with a test light before it even goes into the trunk hinge and there is no power so it looks like an issue with a fuse or something.Thanks in advance for any help or info.
Old 12-11-2014, 02:52 PM
twh
twh's Avatar
My Ride: 2006 BMW 530xi 6MT
Engine: N52
What year and model?
Old 12-11-2014, 03:05 PM
teohenwhy's Avatar
My Ride: 528i
Model Year: 2010
2010 528i
Old 12-11-2014, 04:21 PM
twh
twh's Avatar
Engine: N52
Here is the wiring diagram:
Attached Thumbnails driver side license plate light not working-img_0356.jpg
Old 12-11-2014, 05:57 PM
teohenwhy's Avatar
My Ride: 528i
Model Year: 2010
Thanks , but I am not sure what I can do with this diagram other than knowing the wire is gray and brown which I already know. ??
Old 12-11-2014, 11:54 PM
sanjsanj's Avatar
My Ride: E60 530d
You need a diagnostic cable and INPA or DIS to clear the fault code from the LCM - if that doesn't work, you'll need to use Tool32.
Old 12-12-2014, 12:53 AM
teohenwhy's Avatar
My Ride: 528i
Model Year: 2010
Will clearing the code make the light work again? Are you saying that the light is not working because of fault code? I have a diagnostic cable and Inpa. I am sure that the fault code is still there because the light is still not working.
Old 12-12-2014, 12:56 AM
teohenwhy's Avatar
My Ride: 528i
Model Year: 2010
One that I found is that when I put a light tester to the gray/brown wire that should be the positive wire it actually has a negative output coming from it. Doesn't make sense because that wire should be positive, NOT negative. But if I unplug the light socket from the plug , it no longer is negative.
Old 12-12-2014, 03:45 AM
sanjsanj's Avatar
My Ride: E60 530d
Yes exactly that - if the wires were actually touching and shorting each other, the light module would have disabled that circuit if it happens 10 times in a row. Make sure the problem is properly fixed before resetting it, I think you can only reset it 4 times before it permanently stores the fault code.
Look up the colours in WDS if you want, brown is ground in the headlights of my car...
Old 12-12-2014, 05:26 AM
twh
twh's Avatar
Engine: N52
The wiring diagram has the wire colors and fuse number.
What sanjsanj says is true. The electronics can detect a short circuit. If it detects it repeatedly, it just decides to never again energize that circuit! I don't remember where I read that and I don't remember what the exact procedure for reseting the short the circuit was. You should be able to find it with some searching.
Quick Reply: driver side license plate light not working
