Drive Cycle not resetting!!
My Ride: 05 545i
2005 BMW 525i 90K miles
Had an issue with ground cable due to battery not holding a charge at all.
Took it to Peter Pan BMW Burlingame CA. fixed
Now its time for smog, and the drive cycle will not reset.
Its been driven over 1500 miles . ive disconnected the battery also but no luck.
Catalyst-not ready
oxygen sensor-not ready
NO CHECK engine light.
HELP!!!
Does computer need update?
Catalyst-not ready
HELP!!!
drive cycles aren't based on how many miles you drive. certain conditions have to be met in order for the vehicle to register a drive cycle. BMW had a specific outline of how to create a drive cycle. I don't remember what it was but it was a pain in the neck. you had to drive at a certain speed for so many minutes and then at a different speed, etc.
JonathonK
E34/E28/E12 Discussion
05-07-2015 12:49 PM
