Drive Control System Failure
My Ride: 2003 E60 520i Black Metalic. Glass Sun Roof, Climate Control High, Bluetooth, Leather Memory, PDC, Adaptive Xenon, Navi Pro, Voice Control, Ipod, Folding rear seats, OEM 172 19" Summer Wheels, OEM 138 17" Winter Wheels.
Hi
I have a few times had a failure where I get a "yellow warning" saying "Drive Control System Failure, Drive Moderately" - or something like that
After the failure occurs, the adaptive lights no longer turns, and the indicator light no longer turns off after making a turn. So, I assume it has something to do with a sensor somewhere on the steering column?
Has anybody else had this problem, and is it a easy fix to change the sensor? Does anybody know where the sensor is placed?
BTW: After turning the car off and then on, the problem goes away - but then comes back after some random amount of time.
Any input is appreciated.
Thanks,
Thomas.
![Wassat](https://5series.net/forums/images/smilies/imported/wassat.gif)
Thanks,
Thomas.
Originally Posted by turboawd' post='1043949' date='Oct 30 2009, 09:18 PM
it does sound like a steering position sensor problem.
check out realoem.com and see if you can find a part in the column.
My Ride: 2004 545i Sport, ti silver/gray, CWP, Logic 7, PDC, Nav, elec shade, lumbar, FDRS
2000 Honda CBR 929
1999 Lexus GS400, Nakamichi
It might be low battery voltage.
My Ride: 540i
Model Year: 2017
I don't think it's a DIY because of dealer coding.
http://www.google.com/cse?cx=partner-pub-7...L&sa=Search
My Ride: Estoril Blue 440i GC
Model Year: 2017
Sounds like the Steering Angle Sensor, which is located behind the steering wheel.
The sensor is not seriously expensive, but it does need to be coded to the car, so you will need either a $tealer or someone with the requisite equipment.
There was a bad batch of these Sensors in 2005 I understand, and there is now a modified part (check out RealOEM for part number and cost).
I'm having the same trouble at the moment. All my $tealer has done is reset the error message, which lasted a couple of days before the error returned. My error comes on most of the time when I start the car, but there are no ill effects like lack of indicator cancelling. When my car was on the Diagnostics, they couldn't find anything wrong - I just need the time to take the car back for them to relieve me of more of my hard-earned cash.
Mike
Mike
Thanks for all the replies! Did not know the sensor needs coding at the dealer. Better go talk to them and see what the say. The car is from 2003, so probably not covered by the mentioned recall. Is there anybody who has a reference to the service bulletin where the recall is mentioned?
Thanks again,
Thomas.
Thanks again,
Thomas.
Model Year: 2017
In true BMW tradition, as far as I'm aware, there has been no recall for the Steering Angle Sensor - it is just replaced when it goes wrong.
There's a number of posts on this forum, and most of those cars affected seem to have been done whilst still under warranty - something that doesn't apply to us unfortunately.
I think it affected mainly 2005 cars, and as yours is an '03 and mine an '04, it could be something completely different!!
Mike
Mike
My Ride: 2004 BMW 545i Titanium Silver
Just happened to me today on my way to work ![Frown](https://5series.net/forums/images/smilies/imported/sad.gif)
Will be hooking up GT1 today to my car to read out the codes and see possible solutions. Spoke with my mechanic and he mentioned that if SZL is not at fault then only optical disk might need to be replaced and that does not require coding
otherwise I will be heading to the dealer and I can't code MOST car with my GT1.
Awest91
09-17-2022 11:05 PM
TexaZ3
05-06-2015 09:54 AM
