Drip drip from coolant
So after clearing all the codes on the car and driving it for a day I’m only getting 2 codes, 1 is for transfer case fluid which is getting changed as I type and the other is for this blind operation. I looked around the radiator and I don’t think the car actually has them. I’ve read that m sport versions do not have the blinds…technically this isn’t an m sport but it does have the performance pkg.
Mechanic is checking it out but if it does have blinds and they were stuck closed, I’d imagine the car would continuously over heat…and maybe break a climate control valve…I’ll post what the mechanic finds.
As i recall, this car does not have the active radiator blind/shutter. I seem to remember getting this code before, but I may be mixing that up with a different car.
