Dreaded Passenger Restraint Malfunction
Old May 10, 2017 | 01:20 AM
kevesp's Avatar
My Ride: 2005 525i
Default Dreaded Passenger Restraint Malfunction
So out of knowhere the other day, I got the dreaded passenger restraint malfunction. I had just dropped my friend off who was sitting in the passenger seat. When I got back in the car to leave, the error popped up once I started the car. I plugged in my Carly reader and got the following codes. I've omitted the rest, but if anyone can tell me if this is just a bad BST cable or something else I'd appreciate it. Also, if anyone knows what the other fault codes are I'd appreciate that too!
Code:
iPhone Fault Report - Carly for BMW  - 30.1.2 - 2017.04.26.1833 FV
 ID1: 96396C7F-2193-4E2A-82A1-FA9D4B1F7E2E-10633-00000D1658ACA4E5-ac6
 ID2: 67E6FEC6-0B2D-46A3-950E-E101ADA680D1-10633-00000D1658ACA7AB-125c
INFO: >090EDACDB0A39D856C5B593B331E7<
 2017-05-08 18:28:46
BASE: E60 E61
BUILD-YEAR: 2005
MODEL: 5 (E60) Automatic engine recognition (85)
ADDITIONAL OBD: OFF
FAULTS: 15
ECUs: 32
BATTERY: 13.8V
DEPTH: Normal communication
SPEED: normal
CONNECT: Fast Connection
VERSION: 10.3.1
DEVICE: >iPhone< >iOS<
WIFI: >Carly Adapter v00<
ELM: ><
COM+: >UNKNOWN<
0. Motor Control:
Engine / Motor:
- ECU OK, no fault code
1. ABS / DSC / Brake:
Active Roll Stabilization / Rollstabilisierung:
- ECU not present/no answer
Dynamische Stabilitaets Kontrolle / DSC:
2. Airbag:
Advanced Crash and Safety Management (ACSM):
Satellite front left door / Tuer vorne links:
Satellite front right door / Tuer vorne rechts:
Satellite B-pillar left / B-Saeule links:
Satellite B-pillar right / B-Saeule rechts:
Satellite center / Mitte:
- Fault: sorry, unknown DTC fault
- Code: 009AFF
Airbag B-pillar left/ B-Saeule links:
Airbag B-pillar right/ B-Saeule rechts:
4. Instrumentation:
Central info display / Zentrales Display:
- Fault: CID failure
- Code: 00A46D
5. Light/Rain Control
Rain/light sensor / Regen-Lichtsensor RLS:
- Code: 00DA44
Light / Licht:
- Code: 00A8AA
- Code: 00A8AF
- Code: 00A8AE
- Code: 00E51D
- Fault: unknown failure
- Code: 00E51A
- Code: 009CC6
6. Heating / AC:
Air conditioning / Klimaanlage:
- Fault: Short circuit to positive or open circuit - additional water pump
- Code: 009C77
13. Systems
Steering column switch / Lenkstockschalter:
- Fault: LWS fault
- Code: 0094E7
- Fault: Horn error sound 2
- Code: 0094F9
- Fault: Maximum steering angle exceeded
- Code: 0094E4
Center-Konsole:
- Fault: MFS fault
- Code: 009FEB
14. Anti-theft alarm system:
Theft alarm / Diebstahl Warnanlage:
- Fault: Fault in the battery
- Code: 009D12
Old May 10, 2017 | 12:59 PM
DrMarc's Avatar
My Ride: 545i
That's a resistance too high code on the BST
i would splice in a 2 ohm resistor and call it a day
