DPF removal
Hi guys just wOndered if any of u guys know.... If I delete the dpf how drive table is my car.... As the guy that does my maps and the place that make my exhaust are about 130 miles apart lol cheers for any help in advance
My Ride: '55' 520d m sport
i asked the guy who remapped mine if i could drive without the dpf and he said it would be fine. i didn't do as many miles as that but everything was ok no error messages or engine management lights so i guess you will be ok.
My Ride: Bmw 530d 2004
You'll be fine that 130 miles without the DPF. If it happens that the car decides to start the regenerating, the sound may be interesting, but nothing more .
- Antti -
- Antti -
Model Year: 2015
Engine: N55
Your problem might be the MOT test.
Make sure you know what the effect on your emissions will be.
I know plenty of cars do not have a DPF, but are they set up differently to reduce the junk out of the back?
I understood that the OP is going to a programmer and get the DPF removed from the car's software as well.
At least here in Finland there's nothing in MOT test where they would measure anything concerning the DPF. Of course, if the authorities notice that there's no DPF in a car which should have it, you may run into problems. I would solve this by removing the DPF physically, then removing the filter part inside it, and then installing the empty can back. Then I would remove it from the software.
- Antti -
- Antti -
