Does a replacement used IHKA have to be recoded?
My Ride: 2010 535XI touring (E61)
Hi everyone,
Simple question. After much troubleshooting it's clear that my IHKA is not putting out a signal to engage the relay for the heated rear glass. It's not work since I have owned the car (few months) and am pretty sure the IHKA is at fault. I want to get a used unit and install, will this need coding? I have the cable and software installed (and it works) but I am unfamiliar with it enough where I am not confident about coding modules yet.
Thanks you!
Thanks you!
My Ride: e60 530i e21 320i
Model Year: 2005 1981
Engine: M54 M10
Have you pulled the codes from the IHKA module using a BMW comparable OBD code reader and not a generic reader or BMW software, such as INPA or ISTA or one of the other BMW software packages? Anything else is just guessing.
My Ride: E60 525DA
Engine: 525 M57 straight six @225BHP
The IHKA module needs coding, if not it will use the setings and parameters from the other car not yours. The simple way to do that is with NCS Expert. I can help you, remote coding via Teamviewer.
My Ride: 07 550i Sports Package
As already stated, the IHKA will need coding. I have made that switch before. First change the VIN number then use a blank .man file to take it back to new. I have a couple tutorials if Vlad doesn't workout.
DR545
Feb 12, 2019 03:14 PM
MORI3L
Mar 29, 2012 05:40 PM
DeineMutter90
Oct 18, 2011 06:55 AM
