Does this look like a proper wheel alignment
My Ride: bmw 535xi
I went to the shop and had tires done I got goodyear eagle f1 allsymeterics on my 2008 535xi they said the 2 red cambers on the front and rear is normal and the manufacturer does not specifie what do you guys think
My Ride: 530i
Engine: M54
they're in the red, but they're close relative to one another. did they perform it with you sitting in the car? i suspect that LF camber angle will be a LOT closer to the right side with you sitting in the car, assuming they did it with no load on the left front.
If that were my car I would be OK with what's on that sheet. My $.02.
My Ride: bmw 535xi
I think they had someone sitting in the car as the guy was doing it but as long as it looks ok i just dont want the tires wearing rapidly when their not suppose to because my friend had a issue when is alignment in his 2008 535xi and the inner rear tires were almost bald in 8000 miles they gave me the printout sheet along with other sheets I'll post them...I just spend like 250 a tire and u don't want nothing going wrong with them
My Ride: 07 550i
I had my front camber and toe set to 0 degrees. In the rear they were able to get both to -.75 degrees, providing much better tread wear.
Most shops will not take the time to adjust properly.
My Ride: 2009 BMW 550i
Does getting an alignment also straighten out the steering wheel on these cars? Steering wheel is a little to the right when going straight. Noob, sorry if this is a thread jack...
My Ride: 2008 535i sport
TexaZ3
05-06-2015 09:54 AM
