Does anyone here at the forum have a AFE Cold Air Intake?
My Ride: 2004 e60 M5 Replica
Titanium Silver
Premium Package
Premium Sound Package
Adaptive Xenon's
Apple iPhone cell interactive pared with iDrive Bluetooth setting
19 inch BMW OEM 166M rims,
Michelin tires
Sprint Booster - V2
Fidelity / BMW Extended Warranty 7 year / 100,000 miles
Does any 5 series forum member have a AFE Cold Air Intake on their e60 BMW?
Does any member have a DINAN Air Intake or a DINAN High flow throttle control on their e60?
PM me if you do.
Thanks in advance!!
Eddie aka Presley348
PM me if you do.
Thanks in advance!!
Titanium Silver
Premium Package
Adaptive Xenon's
Michelin tires
Sprint Booster - V2
![Thumbs down](https://5series.net/forums/images/icons/icon13.gif)
_______
AFE or one or two RPI scoops from JOE AT TRINITY? WHICH IS THE BETTER WAY TO GO FOR ADDED 7hp and aggressive sound? AFE OR RPI?
Thanks forum in advance!!
Eddie aka PRESLEY348
-AFE definitely worse than RPI scoop. AFE intakes have been dyno-proven to rob E60 of horsepower, while RPI scoops with BMC or K&N air filter have been proven to add power.
-If you have a 6 cylinder, you can only use one scoop. You can mount a second one for the looks. If you have an N62 motor, you can follow a DIY (there's one or two on this forum) to make the second intake and this actually adds performance.
-Dinan intake is expensive and makes no sense, when considered against the RPI scoop. I recommend instead buying some heat-shield wrapping and applying it to your intake and exhaust tubing - particularly around those parts, where engine radiates most heat. This can significantly reduce the intake air temperature. HP Output = +1% HP per 10 degree temperature decrease, and accordingly, -1% HP per 10 degree temperature increase. So if you manage to decrease the intake temp by 10 degrees, your car's HP output will increase by 1%.
-Dinan HF Throttle body may not be the best way to spend money, unless you already have an RPI exhaust, ECU tune or at least a piggy-back ECU tune, like the BMS power box they have at Burger Motorsports. It is a marked improvement and a legit mod though.
