Do you have to remove the radiator to change alternator on 550
Old 11-26-2013 | 03:43 PM
  #21
Gee_115's Avatar
My Ride: 07 550i Sports Package
Ok, so I did the alternator today. It was a little tedious but not as bad as I thought it would be. To clear up the confusion you do have to remove the fan and it does have lines running through it that has to be removed. There are two lines running through the fan shroud, one at the bottom and one at the top on driver's side. Each line is held in by one hex bolt then easily pops right out. After releasing the lines you have to fold in the tab on the fan on the drivers side. disconnect elictrical plug then pull the fan stright up. Here are a few pics for clarification.
Attached Thumbnails Do you have to remove the radiator to change alternator on 550-imag0614.jpg   Do you have to remove the radiator to change alternator on 550-imag0616.jpg   Do you have to remove the radiator to change alternator on 550-imag0617.jpg   Do you have to remove the radiator to change alternator on 550-imag0618.jpg   Do you have to remove the radiator to change alternator on 550-imag0619.jpg
Old 11-26-2013 | 04:02 PM
  #22
E60I's Avatar
My Ride: 2006 BMW 530I
Model Year: 530i
Congrats, you did it!
The first time is always the hardest for everyone.
socale39
09-05-2023 08:30 AM
E60I
04-30-2015 05:07 PM
Stranger12
04-12-2015 02:07 PM
Stranger12
04-05-2015 10:42 AM
mantraguy
03-09-2015 02:56 AM
Quick Reply: Do you have to remove the radiator to change alternator on 550
