Diversity Antenna Issues
Old Sep 19, 2023 | 09:21 PM
Rolf's Avatar
My Ride: 2006 530d e60 Black Professional Pack
Engine: 530 Diesel
Angry Diversity Antenna Issues
My 2006 E60 has just had a new genuine Diversity Antenna installed due to Comfort Control Issues and a weak radio and TV reception. Radio/TV reception still poor and Comfort Access operates only when the key fob is next to the door handles. Remote lock/unlock operates but also only within 2 meters from the car. Would appreciate any ideas to help resolve this problem.
Old Sep 23, 2023 | 10:00 AM
BIC626's Avatar
My Ride: 2006 530i [Alpine White,Maya RT5¿]
Engine: N52 Magnesium
Im having same issue and i have to literally be next to the door and even that wont get the signal. I have to press both buttons unlock/lock a few time simultaneously and itll catch it. Any luck?
Old Sep 25, 2023 | 05:18 PM
Rolf's Avatar
Engine: 530 Diesel
The diversity antenna module (imported from Germany) has been installed, however, it seems that it is not making contact with the rear windscreen. Apparently there are a few contact points on the rear screen that need to make a connection. The rear screen has a few built in aerials within it. I think a few minor adjustments will fix the issue. The rear screen had recently been removed to have a new rubber seal installed and as a result the contact points have been either broken or misaligned. I'm hoping that with a few adjustments, the expensive new module ( $800AUD) will work perfectly.
Old Sep 26, 2023 | 08:59 AM
BIC626's Avatar
Ok so correction i have a fucked up ccc unit and i been messing with the fuses. It is working fine now. I would take the cd changer and ccc fuse out so i believe it was the reason.
user 007972497204
Aug 21, 2023 05:51 AM
ASZ
Oct 23, 2015 01:10 PM
Gator335i
Sep 6, 2013 08:27 AM
inde
Jan 8, 2012 05:27 AM
bars_sun
DIY: Do It Yourself
Aug 9, 2008 03:59 PM
