DISA Valve
Old Apr 21, 2016 | 12:00 PM
Alexe60crock's Avatar
My Ride: 08 535i
Default DISA Valve
Anybody know if this is normal or not? I have a vaccum leak and it's been taking me forever to find and still haven't found it. But anyways I took off my DISA valve for the first time since i bought the car and there was a lot of build up. Don't know if this is normal and if it's not does it have any correlation with the vaccum leak?
Also the the valve works perfectly fine. The only thing though is that I was told if you turn the key to the 'on' position that you would see the valve move and when I did the valve didn't do anything.
Old Apr 21, 2016 | 01:01 PM
frchdragon's Avatar
My Ride: 05 530i
I know that the DISA valve gasket, intake gaskets, injector O'rings can create vacuum leaks.
Best is to use a smoke machine on the intake to find the leak.
Old Apr 21, 2016 | 10:58 PM
DanielFD's Avatar
My Ride: 2007 BMW 550i
plus one on the smoke machine, easier way to find a vacuum leak
Old Apr 22, 2016 | 03:01 AM
KyleB's Avatar
My Ride: 530i
Engine: M54
It's just oil residue, oil residue does buildup in the intake manifold because the factory CCV system pretty much sucks. Clean it off and you'll be fine. You might need a new CCV system.
DISA valve is controlled by engine vacuum. So no, just turning the key isn't going to do anything to it since there is no engine vacuum without the engine running.
since you have it off, replace the o-ring. it's dirt cheap and does create vacuum leaks.
Old Jan 2, 2024 | 08:23 PM
jam2reggae's Avatar
My Ride: 2004 BMW E60 525i
Engine: M54
The Disa needs the engine vacuum for the valve/flap to move.
Also, the O-ring at the base of the Disa to the manifold connection can crystalize causing a vacuum leak that can affect the engine and O2 sensors. See the videos attached. The easiest way to find a leak on the intake components of the engine is to smoke it using a smoke machine.
Also, the valve works perfectly fine. The only thing though is that I was told if you turn the key to the 'on' position that you would see the valve move and when I did the valve didn't do anything.
File Type: mov
File Type: mov
File Type: mov
Roxann Gardner
Jan 29, 2019 08:28 AM
carl0s
Sep 26, 2014 07:35 AM
chapmanw
Dec 13, 2013 06:55 AM
jlshand
Jan 23, 2012 12:51 PM
khooger
Aug 4, 2009 04:42 PM
