AT and differential info...545i
My Ride: MY05 545i
Hello everyones!
I've a "strange" question...
I don't find any indication into the user manual concerning the differential oil change and density
Same story for the Steptronic.... which oil have to be used? How many km is the maintenance interval?
My dealer told me they are "lifetime" it means no change no level check...
It's true? my car have 2 years and 56k km's.... do I've to change the oils???
I've checked into the TIS but it's in german and I've some problems to understand all...
thanks a lot in advance for your help
Ciao to all
V8Kibrit
Ciao to all
V8Kibrit
My Ride: 09 E90 M3
Originally Posted by V8Kibrit' post='406661' date='Mar 25 2007, 10:36 AM
mmm :thumbsdown:
more than 50 visits and no one have any idea....
BMW specifies lifetime on the gearbox and diff fluids. Since BMW does not specify what lifetime is (100K? 200K?) I change them between 50k and 80k. I haven't change them in my E60 but I have changed them every 50k in my M3 and the difference is very noticeable.
I can probably look at the TIS and get you the specific part numbers but you need to provide us with the specifics of your car. Keep in mind that M cars have LSD and therefore need different oil. There is a specific SIB issued for this as many dealers have filled the ZF diffs with the wrong oil causing grinding after a while. Also BMW does not sell those fluids by the quart but rather with the gallon at about $60/gallon. So you may want to find somebody else who is due for diff oil change.
A good alternative is RedLine 75W90 and Lubromoly LM 75W90 Synthetic Gear Oil for the differential. RedLine MTL for manual transmissions is also good.
Originally Posted by Blackonblackonblack' post='406866' date='Mar 25 2007, 08:06 PM
If I may ask, what kind of difference do you see or feel, is it with acceleration, a smoother idle, or??? Thanks.
I hope this answers your question.
