Differential fluid change interval
Old 07-15-2014, 03:15 PM
  #21
txag_530i's Avatar
You have to remove the fill plug and suction out the old fluid with a fluid extractor (like the Mity Vac Fluid Evacuator) or simple hand-pump. You replace the fluid in the same fashion. There's no other way to do it without dropping the rear axle to get the differential bolts clear of the back frame of the car. Fu%^&*g brilliant design from BMW.
Old 07-15-2014, 03:17 PM
  #22
txag_530i's Avatar
Originally Posted by gcalo
That is an involved process.
I will take a look under there again but have designed a fill plug for the drain so none of that action is necessary.
I have to finish the drawing and then send to my machinist
If the drain is on the bottom of the device then how do you propose to get the replacement fluid to the correct level?
Old 07-15-2014, 05:19 PM
  #23
gcalo's Avatar
My Ride: 530i
Engine: N52
I have designed a plug for the drain that will have a center portion that turns to open w/in the differential, has a 1/4" hose connection, and it will enable one to pump in 2 qts of 75W90 Redline (or whatever determined fluid), turn to close, and that's it.
Going to our machinist who makes all our parts for our license plate holders
Piece of cake!
Old 07-19-2014, 11:43 AM
  #24
gcalo's Avatar
My Ride: 530i
Engine: N52
Measure what comes out after the draining.
It should be about 2 liters.
Replace with the same amount.
Old 07-19-2014, 05:23 PM
  #25
Booyaazaa's Avatar
How's the plug coming?
Old 07-19-2014, 09:19 PM
  #26
gcalo's Avatar
My Ride: 530i
Engine: N52
Have the design done.
Refining a few small issues then it goes to machinist for samples
Old 07-21-2014, 06:17 AM
  #27
best1's Avatar
My Ride: 2008 550i M-Sport
My diff is leaking at both half shafts. Looks like I will get new fluid.
Old 07-21-2014, 06:21 AM
  #28
gcalo's Avatar
My Ride: 530i
Engine: N52
That is a bummer.
Sounds like your seals have gone bad.
All the more reason to change the oil regularly.
Old 07-22-2014, 06:47 AM
  #29
best1's Avatar
i changed it at 80K. now at 113K. Indy said it is a common problem on these cars.
Old 07-22-2014, 07:01 AM
  #30
gcalo's Avatar
My Ride: 530i
Engine: N52
I am very lucky then because at 114,800 miles my underside is dry.
No leaks on diff either
Quick Reply: Differential fluid change interval
