Did a obd scan for fun
Originally Posted by ta0sum' post='851393' date='Apr 18 2009, 07:02 PM
p0597-thermostat heater circuit/ open what is that suppose to mean? is that bad? do i replace something?
P0597 - Thermostat Heater Control (THTRC) Circuit Failure The Comprehensive component monitor (CCM) monitors the THTRC circuit to the PCM for high and low voltage. If during testing; voltage was to fall below a calibrated limit for a calibrated amount of time the test will fail and set the DTC and MIL. Open or shorted THTRC circuit - Open VPWR - Open or shorted thermostat assembly - Damaged PCM
If it shows up again, you should take it to your dealer. It might be covered under your emissions control warranty.
Model Year: 2005
Originally Posted by jagbagri' post='851518' date='Apr 19 2009, 07:27 AM
Which OBD (or OBDII) scanner did you use? From where and How much?
Care to take a picture of the scanner in action.
thanks
thanks
+1
My Ride: 2005 BMW 525D M-SPORT // Grey // SB attached
thanks
thanks
Originally Posted by ta0sum' post='852008' date='Apr 19 2009, 04:29 PM
http://ucables.com/img/pics/OBD2-CAN.jpg its call a innova obd2 scan.
