Delayed tranny fluid change responsible for idle vibration and engine?
dude "tranny warning only came on once" Once is wayyy too much when your talking a tranny fault.
However I do not think your rough idle or CEL is due to this-CEL is an emissions relate warning light--so anything that changes or screws up the amount of emissions gases beyond a certain level--so spark plugs, coils, any drivetrain pieces, cylinder misfires, o2 sensors, gas cap open--did you check your gas gap is properly closed?
Rough idle could be rom lack of driving it more than anything---
Lots of things but nonetheless your tranny is probably fine--for now. You DEFINETLY shortened the life of it that is a no brainer--I would be getting an extended warranty that is forsure from someone as this tranny will fail--just a matter of if it is you or the guy you sell the car to this year to avoide having to pay for that 10k damage
My Ride: Navy 550I
The same thing happened to me. I took the car in for a check-up, and the dealer told me the tranny fluid has a minor leak. It was priced at $500 bucks with labor. At first I was like NAAAA I'm good, but then it ate away at my mind of tranny damage, and I went ahead and fixed it. Now no worries, and some warranty. Sooooo with that being said your a fool to let it go so long. Don't take it the wrong way, but with these cars you want to be on top of everything.
You can get a used tranny for half of that if you look around-plenty out there from multiple vehicles--but I am afraid this is a 10k dollar repair if you want to use OEM--even bmw will try to replace it with a remanufactured unit which probably will run 5k USD without labor.
I would say 7500..
I would say 7500..
socale39
09-05-2023 08:30 AM
TexaZ3
05-06-2015 09:54 AM
