Dealer Story about OEM Batteries vs. Aftermarket
Old 05-19-2009, 07:11 PM
CWS530's Avatar
Here's the diagram:
http://www.realoem.com/bmw/showparts.do?mo...hg=61&fg=30
The hose comes with the battery or attaches to an outlet on the battery? I thought the vent hose stayed in the car and you removed the battery and hooked up another to the same hose? In essence, the battery has a vent hole, but the car has the hose? No?
Old 05-19-2009, 07:12 PM
heavy_g's Avatar
My Ride: '05 545i
http://forums.e60.net/index.php?showtopic=68522
see post #11
Old 05-19-2009, 07:14 PM
heavy_g's Avatar
My Ride: '05 545i
Originally Posted by CWS530' post='883865' date='May 19 2009, 08:11 PM
Here's the diagram:
exactly. but some batteries don't have the vent hole. that's where the OP's issue is.
Old 05-19-2009, 07:15 PM
NoName545i's Avatar
My Ride: 2004 BMW 545i Sport Package, Titanium Gray II Metallic, Wheel Style 124
id say the German Battery is better only because it says Made in Germany lol
Old 05-19-2009, 07:27 PM
CWS530's Avatar
Semantics strike again!
Old 05-19-2009, 10:19 PM
NobleForums's Avatar
Originally Posted by heavy_g' post='883856' date='May 19 2009, 08:04 PM
here's a close up of the tube:
Can you blow up that jpg a bit? It's a bit hard to see with such a small picture.
Old 05-19-2009, 11:16 PM
newt's Avatar
Aftermarket batteries *with* vent tubes are available for BMW's. I just picked up one a few years ago for my 3er.
Originally Posted by Howitzer' post='883777' date='May 19 2009, 07:04 PM
So my 2004 530i was at the dealer yesterday and today to seal up the vent that is located in the trunk in the battery compartment because...... it was accumulating water. Thats right! WATER, about 3" of it... near the heart of ALL the electrical components in the car! How freaky is that? Well apparently this was a known issue and BMW released a bulletin on it or whatever. My dealer was nice enough to fix the problem under my CPO, (but its normally only covered under factory).
To get to the point... the dealer said they were concerned they noticed an Interstate battery there and not an OEM one. I said: "why? Its either I replace it via you for $330 or via myself for $80." They are exact specs as OEM. Well the "service advisor" stated that the OEM battery has a vent tube but the aftermarket does NOT. Therefore, the problem with that is acid cannot drain when the battery becomes hot or whatever and it can cause corrosion at the top of the connectors, etc.
You guys confirm this? I mean, am I going to burn a damn hole in my trunk from battery acid seeping all over the place, end of the world scenario like the dealer made it sound?
Old 05-19-2009, 11:33 PM
Phantom Mark's Avatar
My Ride: E60 530d M-Sport
took the words from my mouth
Old 05-20-2009, 05:29 AM
Howitzer's Avatar
One posted the following:
if you mean the grey one, that is the vent tube. it goes out of the car. you need to connect this to prevent the buildup of hydrogen in the trunk.
So if there is excess buildup of hydrogen in the trunk, whats the big deal if I open my trunk up every couple of days and close it? Same thing ya? VENTAROOOOOOOOOOO! !??!
Just tell me the dealer is full of it and I'm not going to corrode my electronics because my battery can't pass gas? lol
Old 05-20-2009, 05:35 AM
545felix's Avatar
My Ride: 05 545/6
Just tell me the dealer is full of shit and I'm not going to corrode my electronics because my battery can't pass gas?
the dealer is giving you the corporate line. which model interstate do you have? we can look it up and see if it has a vent hole. it should if it's the same size as the factory one. the ones you get at batteries plus (that werkes black one posted in this thread) definitely have the hole, and you can just re-use the elbow and rubber hose from the factory battery. I've done that on several BMWs now.
Quick Reply: Dealer Story about OEM Batteries vs. Aftermarket
