Dead Car?
My Ride: E60 530D(ex armed response)
Model Year: 2005
Engine: M57
So after driving yesterday with no issues at all today my car appears to have no power to idrive headunit or instrument cluster. No lights on dash whatsoever when the key is turned from off to position 2. I’ve removed the battery which is new and tested it and it’s showing as fully charged and 89% healthy. Opening the boot/trunk and disconnecting the negative terminal and reconnecting I can hear the relay doing things. I’ve removed and checked the kcan and mpm from under the wheel well cleaned up and reinstalled and tried again but still nothing. Any suggestions greatly appreciated 🙏
Model Year: 2005
Engine: M57
There is no power. INPA doesn’t detect ignition or battery even when turned to position 2. Ista won’t read anything either through icom or dcan cable and generic obd with car scanner also doesn’t connect.
Model Year: 2005
Engine: M57
RichieB24
05-07-2010 02:04 PM
