Dead battery - Nothing is happening- Please help
Hello All,
I was out of town for 2 weeks, when Came back, car didnt respond to key button. So I opened the door with key (physically). Lights didn't turned on.
then I tried jumping the car (from under the hood) with friends car (with proper poles) but nothing worked. Nothing is starting, No lights nothing
Please help
thanks
Please help
thanks
My Ride: 14 550i
Are you sure there was a solid connection between the cars? Sometimes when I'm jumping I think there is but when I use a voltmeter to measure the volts, there's nothing.
Try moving the connectors around. Also, how did you hook up the jumper cables?
Michael
Acute Performance
Michael
Acute Performance
Originally Posted by amolwankhede' post='898361' date='Jun 2 2009, 04:19 PM
Hello All,
Please help
thanks
Please help
thanks
Michael
Acute Performance
Michael
Acute Performance
Then the other car was running. I did the same thing in past and it has worked
I really dont want to tow it to dealer
thanks for help guys
Originally Posted by craigm1841' post='898367' date='Jun 2 2009, 06:25 PM
check your battery terminals for corrosion
Service center has changed the battery about an year ago when car got its last warrenty service
Originally Posted by amolwankhede' post='898369' date='Jun 2 2009, 07:27 PM
After opening the hood, I connected the +ve to a clip that is under a red cap. Then -ve to ground. that is to a aluminum bolt like knob.
2. check your battery terminals. for real.
I would put another battery on it as its likley that your immobiliser has drained all the power out of your battery, check all the connections also if jump starting!
Originally Posted by amolwankhede' post='898371' date='Jun 2 2009, 07:28 PM
How do I do that?
Originally Posted by craigm1841' post='898376' date='Jun 2 2009, 06:30 PM
its in the trunk. check the owners manual. it is the time of year where terminals get nasty. there is even a problem with some e60 batterys getting completely wet from otuside water (dont know anythign about that)
thanks
My Ride: 14 550i
when you connect it up your car's lights should come on strong.
Originally Posted by amolwankhede' post='898381' date='Jun 2 2009, 04:33 PM
All right. I will reply back you guys on this.
thanks
thanks
