Dash cam fuse splitter
Old 05-09-2017 | 04:56 AM
scottalexander's Avatar
My Ride: 528i
Model Year: 2010 528i e60
Engine: N52k
Default Dash cam fuse splitter
I'm installing a dash cam into a 2010 528i.
I need to pull a 10 amp fuse in the fuse box and install a fuse splitter to power the dash cam.
Which 10 amp fuse is not likely to require a purchase of a Scanner Tool to reset or recode the 10 amp fuse when I power it back on?
Old 05-10-2017 | 11:46 AM
NoQuarter's Avatar
Engine: N54
None of them.
You can disconnect the entire battery and nothing requires a scan tool or recoding
