Cylinder 6 misfire
My Ride: 2008 535xi
Engine: n54
I recently just bought my 2008 535xi and did a much needed oil change and decided to do the spark plugs while i was at it. I drove to work perfectly fine the next day then went to go home and it threw a code for a cylinder 6 misfire and was running extremely rough until it warmed up. I double checked the spark plug and even replaced the coil and it seemed to be fine, so I went to work the next day and went to go home, and the same thing happened. It's still throwing the same code I'm just not sure what could be at this point, any help would be much appreciated.
That happened to me on cylinder 5 after installing new plugs, I ended up having to just re-seat the coil connector.
My Ride: 2008 535xi
Engine: n54
I used champion iridium plugs and duralast coils, neither would have been my first choice but i was in a crunch and that’s all that was available
My Ride: 05 530i M54
Model Year: 05 530i
Engine: 3.0 M54
I'll tell you a little story. I had a friend who was having 2 misfires and he was trying to figure it out for a couple months. He had new champion plugs and some cheap coils from the local parts store installed (old plugs champions) and the car still ran like crap. He brought it to me when he found out I work on foreign cars. First thing I did was pull the plugs and saw they were champions. I told him I don't troubleshoot foreign cars with cheap coils and plugs installed and told him to go buy all OEM (of course I told him what parts to get and where to get them from). He came back with the parts and I installed them for him. Guess what, all his issues were gone even the ones they didn't think pointed to the cylinders. I would advise you to start with a good baseline before going in circles. I know these cars are old but it's still a BMW and they are sensitive to what's installed. You just waist money buying parts that don't work in these engines. I understand you were in a crunch but they do sell OEM parts locally and if you can't afford them there's usually a junk yard where you can find at least coils for cheap.
I would advise you to find someone who knows how to troubleshoot these engines to assist with a smoke test to make sure there's no vacuum leak and ensure the coils are clipped in correctly. Also if you are using 89 gas change it to 92/93 whatever you have locally. You have a very basic issue which should be fixed easily.
gman6262 (12-20-2023)
My Ride: 2008 535xi
Engine: n54
