Crank Shaft Bolt
My Ride: 545i
whoops, I couldn't remember if it was 24 or 27...
Was it easy getting the AC belt back on this way? I'm changing my water pump this weekend and hopefully I can somehow remove that bottom bolt without removing the crank pulley. At least someone on a forum said they were able to by using a flex head wrench.
Only thing that sucks is that the water pump i bought appears to not have been any good. My weep hole is still leaking intermittently
My Ride: 2008 550i
Before you think the water pump is bad, make sure you are diagnosing the weep hole leak correctly. There is also another weep hole to the left of the pump on the timing cover of the engine. Water pump weep hole is to the right of the pulley. Since you have a 545i, you may have a failure of the internal cooling transfer pipe if the weep hole leak is from the timing cover.
My Ride: 545i
My Ride: 2008 550i
Your water pump may have been fine, but if it was the original factory unit, it was time to replace anyway.
Take a look at this link (don't mind the incorrectly titled thread):
https://5series.net/forums/e60-discu...i-help-137246/
For further research, you can also search for "coolant transfer pipe" on this forum or even google.
Another one bites the dust... (coolant transfer pipe on N62) - Bimmerfest - BMW Forums is a thread from when I fixed mine. Basically you remove the intake, remove the valley pan cover, cut the old pipe in half to get it out, then install an aftermarket two piece pipe
The alternative is pulling the whole front of the engine apart.
My Ride: 545i
My Ride: 545i
If it's the hole further to the left, most likely it's coolant transfer pipe.
I've been reading on this process now, do you recall how much time it took you to do the job. Will there be a bunch of gaskets to replace once i get the intake off. How hard was that I guess in comparison to the alternator?? Just trying to get my head around it to see what I'm up against.
The only gaskets you need to replace are the intake gaskets and you should also replace the valley pan. It has a gasket/o-ring made into it. That's it for gaskets
I removed the throttle body on my intake, but that was not necessary.
The hardest parts of the job are:
--Physically picking the intake up (I was by myself and it is heavy)
--Getting the seal for the front seated correctly. It is a very tight fit and has to be seated down very well, and access is not so great.
That's about it. The intake bolts can be a pain. The trick there is to get a magnetic pick up tool, put some tape on the end of it, and use it to get the nuts started. Some flexible sockets make it easy to tighten them as well
Basic process is:
-remove all the engine covers
-remove intake tubing/air filter box
-disconnect wires at front of engine that go over fuel rails (knock sensors, water temp., etc.)
-get wiring harness out of the way as much as possible
-remove intake (leave fuel injectors, etc. alone. Comes out as assembly)
-remove valley pan
-cut old coolant pipe in half with saw and remove
-remove old o-ring in rear and clean seal surface thoroughly on front
-install new seals, front and rear. Front is a pain and must be seated properly. This took me a good 2 hours
-Install new (2 piece) pipe per instructions included in whichever kit you buy
-Everything else is reverse of disassembly
![](http://www.goldmine-elec-products.com/images/G19397B.jpg)
My Ride: 545i
Time wise, I could do it in an afternoon now.. but for a first time it basically took me one Saturday to pull it apart and the next to put it back together. That was working in a parking lot though too..
Basic process is:
-remove valley pan
Basic process is:
-remove valley pan
Ok you just gave me more confidence to tackle this job lol. I can drive a week now before the low coolant light comes on so im going to tackle it in about 2 weeks once I have some more time and all of the parts. Ive cut down on driving it due to the leak anyway. I think I'll copy you and use the links you provided for the parts (thanks for that by the way). Just have to get a saw to cut it. I've read not to use an electric drill to clean out the old seal pieces but I dont have access to air tools. What did you use to clean it out?
I just used some brass brushes I found at home depot and did it by hand. I don't think i'd want to use any power tools there personally
