Coolant temp gauge!!
My Ride: G30 M550i
Model Year: 2018
So can anyone confirm that on an M-car, the rev-limiter kicks in variably as well? (In other words, does the limiter follow the red line?) Andy, does a non-M car with M gauges cause the rev limiter to become variable?
Model Year: 2005
Engine: 545i
My Ride: G30 M550i
Model Year: 2018
Originally Posted by noonehome' post='513394' date='Jan 3 2008, 05:43 PM
On my 04 545iA the the tach did not go past those white lines when the engin was cold. It was a long time ago and I only did it once so I don't remenber if the gear selector was in M or DS. But I do distinctly recall the tach did not exceed the white lines( ie go to redline) before the engine was warmed up.
If you install the ACM unit you can get to a menu that shows some basic car values. One of them is the coolant temperature.
Apperantly the collant temp is part of the CAN bus data. I wait with demanding a lot from the car untill the coolant has reached 94 celsius (I know it takes the oil a litle longer to reach the apropriate temperature but the coolant is a good indicator).
Originally Posted by Rudy' post='513408' date='Jan 3 2008, 06:29 PM
Unless I'm misunderstanding what you're saying here, all I can say is if your car's limiter kicked in at the variable white bars, it would be the only one in the world, based on the collective information gathered here over the years...
My recollection of the collective information is the observations came from SMG and 6MT cars, no Autos chimed in. But it doesn't really matter, I was just reporting what I observed.
My Ride: 07 550i Titanium Silver, Black Dakota Leather, Steptronic, Sport, Premium, Nav, Sat. Radio, Logic 7, Comfort Access, Rear Sunshade.
Rudy,
This morning I had my tranny in M mode and the limiter kicked in prior to the variable white bars. It upshifted about 500 rpm prior to the white bars. I didn't get a chance to redline it in DS mode as my commute to work is quite short.
RLo
Model Year: 2005
Engine: 545i
Originally Posted by Bdaddylo' post='513679' date='Jan 4 2008, 07:53 PM
Rudy,
RLo
RLo
Thanks,
My Ride: G30 M550i
Model Year: 2018
Originally Posted by Bdaddylo' post='513679' date='Jan 4 2008, 01:53 PM
Rudy,
RLo
RLo
Originally Posted by Rudy' post='513741' date='Jan 4 2008, 01:11 PM
You really can't test the rev-limiter with an automatic because it will upshift. I'm talking about the hard limiter that you can only hit if you're in an SMG, a manual tranny, or redline in 6th gear of an automatic...
I didn't know for sure, but thanks to this post I was inspired to leave my office and take may car for a spin to verify....just another benenfit of the e60 forum.
