Coolant question
My Ride: E90 M3
Model Year: 2011
So I go to leave work yesterday evening and upon starting my car get a warning message that my coolant level is too low! Having just had the car at the dealer Tuesday morning for an oil change, I was pretty annoyed that they had not checked that basic fluid levels while they had the car. Well, after stopping at the grocery on the way home, the warning message has not come back. Even this morning, another cold start, no message. Anyone ever have a similar issue? I assume I simply need to top off my coolant but was just curious why the message never came back after the single warning. Thanks for any insights.
Ken
Ken
My Ride: E90 M3
Model Year: 2011
Thanks, the water pump or some other leak is my real concern, especially as with the approach of Hurricane Dennis, I may be forced to get out of town (New Orleans) this weekend. My car has 12,900 miles on it.
The dealer must have forgot to check the coolant level. With these cars nowadays, the servicemen do not bother if there is no warning from the obc or their own plug-in handheld.
Just physically check the level and top up should it be required and you'll be fine. The obc sometimes acts up on the oil and coolant level warning.
Originally Posted by Edlee' date='Jul 7 2005, 09:00 AM
.....The obc sometimes acts up on the oil and coolant level warning.
[snapback]146570[/snapback]
Originally Posted by Olivin530i' date='Jul 7 2005, 09:13 AM
I had mine with a "Low Oil Pressure
[snapback]146574[/snapback]
If you do have to top it off, use only distilled water and if you add coolant, use only BMW coolant. Tap water contains crud (calcium carbonate, etc.) that can damage your aluminum and composite components. Non-BMW coolant can cause corrosion.
Originally Posted by gwf545' date='Jul 7 2005, 09:55 AM
If you do have to top it off, use only distilled water and if you add coolant, use only BMW coolant.? Tap water contains crud (calcium carbonate, etc.) that can damage your aluminum and composite components.? Non-BMW coolant can cause corrosion.
[snapback]146587[/snapback]
My Ride: E90 M3
Model Year: 2011
Originally Posted by kscarrol' date='Jul 7 2005, 08:52 AM
So I go to leave work yesterday evening and upon starting my car get a warning message that my coolant level is too low!? Having just had the car at the dealer Tuesday morning for an oil change, I was pretty annoyed that they had not checked that basic fluid levels while they had the car.? Well, after stopping at the grocery on the way home, the warning message has not come back.? Even this morning, another cold start, no message.? Anyone ever have a similar issue?? I assume I simply need to top off my coolant but was just curious why the message never came back after the single warning.? Thanks for any insights.
Ken
Ken
[snapback]146557[/snapback]
