Coolant Message Notify
My Ride: BMW 535 I model 2008
Dear
a message on my dashboard saying that the coolant level is low , and i checked it and it was full to the rim and no water leak found , so whats the issue and the reason for that message .
waiting your soonest reply .
best regards
Abdel Karim
best regards
Abdel Karim
Engine: N54
There is a sensor in the bottom of the large black tank.
If the sensor is going bad, you can replace the entire tank which includes a new sensor. The plastic tanks can develop some problems over time so it is good idea to replace the tank anyway if your car is from around 2008
