coolant level stick broken!
My Ride: 2005 BMW 545i, Titanium Silver. Bridgestone 760s on Weds Bavaria II 18" wheels, standard sport pack size. Sport, AT. Latest job - NGK Iridium IX plugs installed.
Hey folks. The floating 'level stick' in the coolant expansion tank had started flopping around. I pulled it out and started to wipe it down when it just crumbled in my hands. Is this something I can buy as a part, or is it considered a part of something?
Also does the low level alarm work without it? I have been slowly losing coolant, maybe a quarter cup a day from either the lower radiator hose or the thermostat connection.
thanks in advance,
k
thanks in advance,
k
My Ride: 2007 530d M Sport Automatic, Le Mans Edition.Le Mans Blue Individual Paint Special, Syrah Blue Individual Leather, Piano Black Individual Interior Trim, Front seat heating,M Double Spoke 172 19
thanks in advance,
k
thanks in advance,
k
http://www.realoem.com/bmw/showparts.do?mo...hg=17&fg=05
I assume item 2 is what you require.It is required for the level monitoring to function.
i see, thanks. It looks like the white float and the stick are sold as one part. I wonder what is considered the core.
Btw I found out that the low level warning does come on without the stick. It is hard to gauge where the full level is, I filled it till the top of the white float was about even with the overflow.
I can't imagine that it would cost that much to replace. Either your local dealership or Garry should be able to hook you up.
I had the same issue and replaced the entire tank with Part Number 17137542986,
The measuring stick disappeared at around 55K and the red plastic started to disintegrate completely. I could simply break it into further pieces with little or no force whatsoever.
My Ride: 2006 550i sport pak. all the other goodies..
MODS: M5 front, sides, aFe throttle body spacer, RPI Red scoop, amber angle eyes, powder coated sport rims, tinted tail lights. smoked side blinkers, color of car and rims roundels, real carbon fiber roof spoiler, 550i number flat black, LED license plate lights, MTX 12' sub, dyno mat, tinted Windows, flat black grill, flat black exhaust tips, light smoke headlight tint, foged out eyelash, velocity booster.
same with me. 53k-mi. wtf bmw.
Buy the tank and install it yourself - easy DIY and not that expensive. I don't think there is a way to insert a new float and stick into the tank - it just wont fit, and these tanks are known to leak anywhere from 60-100k miles.
+1 BMW!!!!!!!!!!! This happened on EVERY bmw i've owned btw, along with that cotton shit that's part of it.
My Ride: 2006 BMW 550i CPO bought in Jan 2009
Mine broke while under CPO warranty and they would not fix it. I called BMW NA and they too said it was not covered. About a year later the tank started leaking and they replaced that under warranty. Your take will proaly go soon too..everybodys does
