Coolant leaking, what to do?
My Ride: 530i
Originally Posted by tallers' post='1090476' date='Jan 14 2010, 09:37 AM
Well I picked up my car yesterday. As stated above, the temperature sensor was replaced ($40) as well as the return hose ($64). They also replaced the vent pipe ($54). Total cost for parts and labor $700.
Since the car is an '04 I told them to flush & replace the coolant which was the original. Add another $200.
I knew the cost would be a bit crazy but the parts total was only $183. The dealer charges $122.50/hr for labor. Does that sound high compared to other dealers?
My Ride: 2004 BMW 545I SPORT PACKAGE, 20in MRR GT1 WHEELS /W 245/35 front and 275/30 rear NEXXEN TIRES, 6000k HID BULBS FOR HEADLIGHT AND 7000K BULBS FOR FOG LIGHTS, AFTERMARKET HALO BULBS (WHITE)
My Ride: 2005 545i
SPF Cobra #1019
Originally Posted by r9ndy' post='1089624' date='Jan 13 2010, 01:27 AM
+1 my coolant tank had a crack in it too. you should check around the area to see if you can find any cracks, if not pressure test it
My Ride: 2004 BMW 545i Titanium Silver
My car started leaking coolant from the top of the radiator. After removing plate above it found that same vent pipe was leaking. What's interesting that it started after I replaced coolant temperature sensor (on pump housing). I replaced that due to long battle with increased emissions and CEL. It seems like coolant has never reached proper temperature, and after replacing sensor it started to warm up correctly and weakest link (in this case vent pipe) failed. I wonder what's going to be next in this chain effect.
