Coolant leak fixed!!
Old Aug 21, 2015 | 05:31 AM
turbineguy's Avatar
My Ride: 2004 545i & 2000 528i
Default Coolant leak fixed!!
So, I have had my 2004 545i for just over a year now and I had no issues other than a crash sensor and a failed water pump (pretty typical for BMWs). I love this car! Hammering the throttle coming out of a tight corner or passing other cars is soooo much fun. I just wish it handled like my old E39 528i, or at least had the sport suspension. I think H&R springs and some Bilsteins are in my near future.
OK, since this summer started, I could smell coolant every time I got out of the car and was loosing maybe a cup of coolant a month. But I had no visible leaks and never any puddles. That is until the past weekend. A couple of times over the weekend I had puddles of coolant under the car after it was shut off for 15-20 minutes. I added some dye to the coolant as I still could not find the leak. Then yesterday I notice a puddle under the car and when I looked at the engine, the valley area between the heads/under the intake manifold was full of bright green fluid! CRAP!!!!
My first thought was the coolant pipe under the valley pan. I really started to panic! However, upon closer inspection, I noticed coolant dripping from the coolant line that goes from the head to the expansion tank. I pulled off the intake hose/pipe and throttle plate and found a little plastic tee which had broke (why do they continue to use plastic in the cooling systems?) The tee was brittle and fell apart in my hands (See picture). I replaced the tee temporarily until I can order a new hose (maybe time for a coolant hose kit) and all is well!! Wahoo! I love my car again! Sorry for doubting you baby!
Old Aug 21, 2015 | 07:05 AM
JayArras's Avatar
Administrator
My Ride: 530xi
Engine: N52
It feels great when you can resolve your own problem, doesn't it? Thanks for sharing your success story. We need more posts like yours.
tnixa
May 21, 2015 11:01 PM
BigxPx
May 20, 2015 09:39 AM
BigxPx
Apr 23, 2015 10:11 AM
Stranger12
Apr 5, 2015 10:42 AM
NickP
Jul 15, 2004 11:18 AM
