Coolant leak: bottom passenger side of radiator by sensor
It appears I have a coolant leak by the bottom passenger side of the radiator right before the main hose clamps on. There seems to be some kind of wire harness/sensor and the leak appears to be coming from that sensor. Anyone experience a similar leak or know the part number of this thing? See attachment...
too common. It cost me $125.00 to have it replaced. there is another temperature sensor on top of the radiator as well.
My Ride: 545i
Engine: N62
I got lucky and di not have to drain the coolant. I just left it parked in the garage for a few days until the part was ordered. Leave the Coolant Cap On! Do not open or it will release the coolant back into the lines and you will lose a lot. I was able to swap out pretty quick and only lost a few drops. You could also drain the coolant if you want, but it was not necessary. Either way, be prepared for a cleanup just in case. If you search there was a recent thread on this. I think it was started by Quarta2Six.
Found it:
https://5series.net/forums/e60-discu...-loose-140857/
Found it:
My Ride: 04' 545, 6 Spd Manual, Blk Lthr, Sport Pkg, Sport Sts, Logic 7, Cold Wthr Pkg, Full L.E.D. Interior, Red Eng. Cvr, Mtech Front Bmpr, M5 Spoiler, Matte Blk Grill, Red Caps, Slttd & Drlld Rotors, 20
After some searching I see how common this problem is. I think I'll try replacing just the o-ring and see what happens. Thanks for all the good info and tips!
My Ride: 545i
Engine: N62
