Coolant Fill Level
My Ride: '06 530i N52
This may be a stupid question, but I am getting a coolant level low indicator right now. I went to top off the coolant level, but how do you read that dang float thingy? There is a bulge on it near the middle of it. Do you fill until that bulge aligns to something? Thanks.
Sorry I can't help on where to top it off but I got a coolant low warning message and took my car in to have it inspected and it turns out I have a leak and need $400 worth of repairs. Unless you haven't had any maintenance done in a long time your coolant level should not be low unless something is wrong or leaking.
Originally Posted by VW2545i' post='1093188' date='Jan 18 2010, 06:28 PM
Same thing here, ended up needing a new water pump. As for the floaty, I followed the little diagram and filled till it was level.
I think the diagram shows the bulge on the float is level with the top of the tank. Is that correct?
Originally Posted by donpb' post='1093246' date='Jan 18 2010, 09:25 PM
Until what was level? The bulge mark on the float? Level with what?
Originally Posted by e6t.lab.rat' post='1093255' date='Jan 18 2010, 10:12 PM
this is somewhat correct. not the tank per say, but the top of the filler where the cap screws on. just try not to let the bubble on stem go any higher than the top of the filler hole. good luck
ok, after i threw a little light on the situation and was able to see the markings on the top of the tank, it's like you said, the bump/bubble on the float stem should not go any higher (max level) than the top of the filler hole/entrance.
i topped off the coolant and all is well. thanks!
Vman33
Mar 14, 2022 04:43 AM
bestofthebest
Mar 28, 2016 02:47 PM
