Continental Extreme Contact DWS Vibration
My Ride: 2008 535 xi, Comfort Access, Cold Weather, Nav, Parking Sensors, Logic 7
I'm having some frustrations with the Continental Extreme Contact DWS tires I had installed a few weeks ago. I had gotten two flats in 6 months with the original Goodyear RSAs, so I figured I would get all four replaced with the Contis which were highly rated. Now I get vibration between 60 and 70 mph. I had them rebalanced twice without any success. The tire shop showed me that one of the rims seemed slightly bent which made the tire hop. So I got a new rim and the tire shop installed a brand new tire. I thought that would fix it, not so. Same result. Before with the Goodyears, the car was completely smooth all the way to 90+ (even with the bent rim). In fact, I had to look down on the speedo to make sure I wasn't going to fast. Of course, now I know when I hit 60. At this point, I want to go back and have my old Goodyears put back on - not sure if that's even an option. Any suggestions? I hate driving the car now.
assuming your new rim is the same brand as your old one and is hubcentric with the correct bore, no need for hub ring, and all your tires are balanced, try my cheap method to see if it can resolve the issue for you.
Reinstall your rims with the star pattern, but torque each at 20 lbs interval until you get to the recommended torque which is around 88 lb/ft I believe. I know it sounds weird but I had a similar problem between 60-70 mph when I installed my old set of Miro on. It turned out the shop over torqued the lugs since they were using their almight air gun. I've been driving with it past few months without any vibration so far. At least now I find some use for the damn 1/2" drive torque wrench.
GL
GL
I asked the manager of the tire shop about roadforce balancing. He said that roadforce balancing is mainly for racing cars and not regular street cars. Not sure if the shop actually has one. I've never had to do anything special when getting new tires. This is very perplexing. Thanks for your suggestion. I will keep that in mind as an option.
GL
GL
My Ride: 2008 535i
My Ride: 525i M54 2005 Alpine White
Sport/Cold/Premiun Sound/Active Steering
Navigation/PDC/sport seats/6 CD Changer
My Ride: 08 535xiT - Sapphire Black / Beige
I have Conti DWS on my car, no issues. Love em. Your shop isn't balancing em properly. Like other's said you need to find someone that has the proper equipment. Its the shop, not the tire.
Also I think the Contis have 30-day test drive with full refund. Ask them about this. Try to rotate the tires from back to front and see if you still have vibration (on the steering wheel).
Sorry to hear your experience. I've been thru the same with other tires. They finally found out one of them was out of round and replaced it for free. Still, it was a unnecessary hassle.
