When a problem comes along... there is only one solution and that is, to turn to the gods.. those gods are... the E60 gods.
Car: 2006 E60 Sport - 95555Miles - Uni Chip external power and cons chip - serviced last 4-5k History: Uni Chip was fitted by dastek in Oxfordshire - I was so impressed I nearly bought the company. Power amazing, drives like a V6, consumption seemed to be much much much better a. Due to my readings and b. Due to the money being put in the car. ( please note - the uni chip does not mess with the ECU - it works independent of it and takes the information from the ecu and then delivers the altered information to the engine, this is better for many reasons ) Problem - Shock panic alert, my consumption readings are goign mental showing numbers like 67 - 70 - and at one point 72 mpg - Bigger problem - The car is only doing 36mpg!!!!!!!!!!!!! Which is worse than I started. I noticed that covering 110 miles at 60mph for half and country road sedate driving and bends for the rest that I used £18.20 of fuel. Pleeding - What on earth am I going to do? |
| All times are GMT -8. The time now is 04:29 AM. |
