Connect BMW To Laptop
Could anyone please confirm how to connect my BMW (57 plate - LCI) to my Laptop?
I've done a bit of research and apparently you can connect using the OBD port but i can't seem to find it. Apparently it should be on the driver's side by the right kneww but i've only got a storage compartment in mine. Any help is appreciated, picture would be nice.
Thanks
Thanks
I have LHD so I am not sure if it is different but it is on the driver side above or under the "Open Trunk" button.
Here is a pic from an E90, mine is in a similar spot but over the trunk button:
Thank you sooooo much iamnatio you will not believe how long i've been looking for it - it was so neatly fitted i didnt even notice. Thanks once again most appreciated.
Are you planning on doing some code for your ride?
My Ride: 06' 530 Alpine/Auburn/Dark walnut, Sport, Premium, Sirius, 35% Tint
Upcomming mods: M166's/Exclaim UHP's, Mtech
you can actually use a OBD2 bluetooth or usb adaptor and do this from your iphone or android phone (torque application on android now supports USB in addition to bluetooth)
Tons of info here:
http://www.bmwcoding.com/
