4 Attachment(s)
*sigh* Seems like it's never more than a month or two before the car decides to take a little extra portion out of my paycheck. :wacko:
So, anyways... yes - I know about the infamous "Passenger Restraint System" malfunctions. The recall, etc. Searched around quite a lot. This may still quite be the case for me, but I'm not fully convinced yet. This is what has happened so far: I got in the car this morning, burn my rear off on the black leather seats that've just been in direct sunlight for a few hours... turn the car on, and I see this pleasant message: https://lh6.googleusercontent.com/-a...513_133247.jpg I hooked up my laptop, fired up INPA, and start trying to get some more details on any stored errors. It looks like the Passenger occupancy sensor is still functioning as expected.. I verified by getting up and sitting down a few times, and each time the sensors picked up a correct reading. See screenshot #1 below: Attachment 166055 Belt buckles and all are also reporting proper readings: Attachment 166056 I did manage to get this error code reading. If someone here knows some German, a summarized translation could be quite helpful :) Otherwise I'm just going to retype it into Google Translate and go from there. Attachment 166057 Though probably the most telling of the screens I got was this.... Attachment 166058 What is "Ignition Circuit 0"? Below that it says... Airbag Driver Position 1. Is that... my steering wheel's airbag? I sure freaking hope not. I'd like to get some ideas/suggestions/etc before I start taking things apart. :help: |
I have the same error, so I'm interested in what you find out!
Originally Posted by saltdog
(Post 1442099)
If you search around, there is a lot of information about the Passenger Restraint System failing. BMW even has a recall (US only) for it. However... That's for the passenger seat mat. But from what I saw on INPA, the passenger mat is still reporting just fine. Have you pulled any diag info from INPA for your situation? I'd like to see what other people have seen as well. |
Here's the text of the screenshot of the error code readout.
Code:
E R R O R M E M O R Y And an English translation via Google Translate: Code:
E R R O R M E M O R Y |
Dude, if you find out a coding solution to turn off this whole system plz let me know!
I have this same error... |
Just check with BMW, you may be qualified for a free replacement of your passenger restraint system, my 545i was covered. There is a 10 year warranty on them.
I checked at my old dealership in the Detroit area, they told me to kick rocks with no socks...
That's what my dealer said too, but I called Transport Canada who then called BMW to clarify the situation and voila, it was replaced free and with a smile.
Not sure in the US if you have a transport safety agency who take customer complaints and works with dealerships for a solution. Basically the passenger restraint system is a major safety issue, you can't be sure if you have a passenger and god forbid you get into an accident, you are ok, but your passenger isn't. Of course if your car falls under the warranty, which mine did. I would file a complaint and get it done. BMW acknowledged the issue and extended the warranty to 10 years, just like the HPFP on the 535's. Good luck. |
Originally Posted by Shlooky
(Post 1442314)
I'm still going to give them a call and have them run my VIN to see if they'll look at it. But if they want $175 for diag fees, I'll be telling them to kick some rocks and continue searching on my own. @umichchris: I'll probably investigate more into coding the warning away once I can know with confidence what exactly is causing it. If it is legitimately a faulty airbag or similar... that's not really something you wanna bury. https://5series.net/forums/public/st...fault/nono.gif |
2 Attachment(s)
Status update!
I'm putting my "solution" near the top, since you should probably try this before anything else: While I was previously reading the codes, I tried to clear them from within the INPA screen for the specific module (Airbag ACSM, menu shown below): Attachment 166053 When I hit clear.. It would go back, say all codes were cleared... but not really. Everything was still there, and no luck. While poking around (and doing lots of internet searching) I went into the "Functional Jobs" menu: Attachment 166054 From there, I was able to click the "Show EM" (EM = Error Memory) that displayed *all* of the codes stored on *all* of the car's computers. I clicked the Clear EM button, and it wiped everything. I powered off the car, turned it back on.. drove around the block back and forth... and all seems well. No codes came back, no warnings on iDrive, and no lights on the dash. I'm had "solution" in quotes above because I'm not completely sure that this actually fixed anything. It's possible that this may have been a false positive from the seat mat (something could've been jostled, or it could've not liked being in direct sunlight for an entire morning, or whatever). But I have no way of confirming anything unless a code comes back (which I'm perfectly fine if it doesn't!). We'll see how it goes commuting back and forth to work tomorrow. ---------------------------------------------------------------------------------------------------- So, prior to all the above, I tried some other things: While doing a lot of researching, I've found a few possibilities for this error:
In my case... before I managed to clear codes properly through INPA, I pulled the negative plug to my battery and left it for a few mins, then plugged it back in. Errors were still there. But... I did notice something about my battery. It's not OEM! At least, I really don't think it is. It's a DieHard (american-made) battery in there. I don't have much other info on it, but it hasn't given me any issues, but I can't completely discount this as not being a partial culprit to the restraint errors. Anyways - I rambled a little bit, but I'm trying to be descriptive as possible. Perhaps it can lead someone else in the right direction. I'll report back either tomorrow or in a few days to at least say if the error message resurfaced itself or not. |
