5Series.net - Forums
-   -   Concern over Upper Timing Chain Crack (https://5series.net/forums/e60-discussion-2/concern-over-upper-timing-chain-crack-148958/)
naenyc Oct 3, 2018 12:03 PM
https://cimg4.ibsrv.net/gimg/5series...9ed4525612.jpg
Alternator moved to right hand side.
https://cimg2.ibsrv.net/gimg/5series...0e78628e58.jpg
Crack up Upper Timing Chain
First, I can confirm that it is possible to access the upper timing chain bottom bolt on a 2004 545i with active steering. Photo attached.
As stated in other threads:
  1. Lossen Serpentine Belt
  2. Remove top bolt
  3. Loosen bottom and slide to right.
Upon removing the gasket, I noticed what seems like a crack, and not sure if it is significant. If not, do I simply apply a little gasket sealant over it?
Thanks
