Comfort Access
My Ride: 07 530 xiT, ED, titanium gray, Sirius, Logic7, Nav, HUD, PDC, comfort access, comfort seats, butt warmers
For example:
-Is the key significantly larger than the regular key? (Will it tear a hole in a pants pocket, or not fit on a key ring?)
-How often does the battery in the key need to be replaced? How does this compare with the "regular" key?
-If the comfort access electronics die, is there any risk the car will be inoperable? Or is the system engineered in such a way that regular keyed access will always work?
My Ride: 2006 550 SMG
Originally Posted by kurjan' post='257709' date='Mar 20 2006, 01:15 PM
For example:
#1 NO
#2 Same as without C/A
#3 There is a key inside the fob to unlock the doors, and then fob can be inserted into ignition just like without C/A
Originally Posted by katheikia' post='257715' date='Mar 20 2006, 07:35 PM
#1 NO
#2 is not correct: C/A works with a battery, which has to be replaced from time to time (once a year, bmw claims) the "normal" keyfob works with a accumulator which is charged through the ignition: there is no need to replace it (untill it eventually dies...)
My Ride: 2006 M5, Silver Grey, Silverstone Full Leather, Alumium trim, Active/Ventilated Comfort Seats, HUD, Comfort Access, Split Rear Seats, Rear Seat Heating, etc.
My Ride: 2005 545i (SMG)
Titanium Gray
Black Interior, Anthracite Trim
M-tech kit
Sport Package
Premium Sound
Satellite Radio
Active Cruise
Comfort Seats
Navigation
Folding rear seats
The C/A keyfob needs to be *recharged* from time to time, but I have not heard of it needing to replaced, at least not that often... You recharge the keyfob by sticking it in key slot like a regular key. Although, I've only had mine for a month, so what do I know...
Incorrect.
The Comfort Access key uses a normal battery, not a rechargable one. It must be replaced every so often. BMW should replace the battery as part of scheduled maintenance.
SubterFUSE is correct. CA keyfob does not recharge like non-CA keyfob and requires battery replacement.
Think about it - main feature of CA is that keyfob can stay in your pocket or purse. With that as CA's raison d'etre, what sense would it make to require that it be charged in the key slot.
Originally Posted by kurjan' post='257709' date='Mar 20 2006, 02:15 PM
For example:
found a big disadvantage this weekend with my friends cadillac
he wanted to show me the new STS - gave me the keys and told me to put in my pocket - which I did
Then got into his car - started it - drove it around - then left it running for him and got into my bimmer and went home
got a call an hour later from a bar - he was stuck outside of his car - with the alarm going off - and I had his keys at home in my pocket
had to drive to the bar at 2am to give him the keys
My Ride: '06 550i 6 Speed MT, Navigation, PDC, Cold Weather Pkg, Logic7, Prem Pkg, Sport Pkg, Active Steering, Comfort Seats, Comfort Access, HUD, Alpine White on Black Dakota & a Big Grin ;-) <---- On the vessel from Germany...
'05 545i 6 Speed MT, Navigation, PDC, Cold Weather Pkg, Logic7, Prem Pkg, Sport Pkg, UUC EVOIII SSK, Silver Gray on Black Dakota..... (Buy back by BMW NA)
Originally Posted by Veight' post='257894' date='Mar 20 2006, 10:11 PM
The main disadvantage of Comfort Access as I see it...The $1,000 to get it. I can press a button to get in my car. Not getting this, covers half of my Night Vision option.
)...To each his own...
