Cold weather effecting my 545i in a bad way
Old 01-23-2014 | 07:35 PM
Shlooky's Avatar
My Ride: 545i
Default Cold weather effecting my 545i in a bad way
In Toronto, it's been -17 c for the past few days, when i start the car I get the following...
1-Occasionally the engine stutters soo badly I get an engine malfunction error and an emissions error, the engine seems like it's running on three cylinders and very very sluggish.
after 2 minutes when i turn the engine off and turn it back on it's perfectly ok.
2-I get a low coolant error. again this is temporary and then the error disappears.
3-In the extreme cold, Active steering occasionally goes down too with an error code. But corrects itself when it's a bit warmer
4-Not sure if this is the cold, but since I put my winter tires on, there is a burning smell coming from the back end. Sounds funny, but it's true, especially if I driver the car aggressively.
Any ideas?
thanks!
Old 01-24-2014 | 05:40 AM
Gee_115's Avatar
My Ride: 07 550i Sports Package
Keep the car inside if you can. BMW doesn't recommend running the car to warm it up but I always do because the car drives terribly when it is cold. Check to see if the tires are rubbing somewhere.
Old 01-24-2014 | 07:36 AM
ncsugrad2006's Avatar
Does the stuttering / engine light happen on cold starts or just randomly while driving?
Yeah, really need to keep it inside.. that's ridiculously cold
Old 01-24-2014 | 07:45 AM
Shlooky's Avatar
My Ride: 545i
Cold starts only, I live in a condo and I park two levels down, I start the car and It's perfect. but when I park outdoors for the day and start it, all hell breaks loose.
It could be a crack in the pressure valve or something, I will have to check.
This all started in Ottawa when it was -25c...sigh!
Old 01-24-2014 | 07:52 AM
There is a common issue with the intermediate levers that causes a cold start idle issue on the earlier N62 engines.. It's possible that the extreme cold is wreaking havoc on the valvetronic tolerances, but that is a total guess.
I have read that if you unplug one of the VANOS solenoids it will disable the valvetronics system and use the "normal" throttle body. Perhaps you could give that a shot--can't hurt anything, but you're sure to get some errors. Would be interesting to see what happens.
SIB 11 02 05 has more info on the intermediate lever tolerance issue
Old 01-24-2014 | 09:22 AM
JayArras's Avatar
Administrator
My Ride: 530xi
Engine: N52
The burning smell could be your brakes! I never use the emergency brake when the temperature drops below the teens. Often, it will freeze up and not release, or only partially release and then it burns up your brakes. Leaving the car in a gear (manual) will keep it from rolling.
Old 01-24-2014 | 09:27 AM
Shlooky's Avatar
My Ride: 545i
Good point, I will test without applying the emergency break when the car is parked.
Thanks all for your suggestion. I will have to take her in anyway to see what is going on.
Hopefully one more month of extreme cold temperatures and the Miro's go back on!!
Old 01-31-2014 | 07:24 PM
Dremers's Avatar
My Ride: FX35 Supercharged
I have a mild issue of 1 and 3.
Old 01-31-2014 | 07:53 PM
pcb5's Avatar
My Ride: 545i
I'm having the same issue with intermediate levers and cold starts. Where are the VANOS solenoids located? I would like to give this test a try as well. Will it hurt to drive it like this?
Old 02-01-2014 | 05:50 PM
mag5qc's Avatar
My Ride: 2004 545i, Mystic Blue, Dark Beige, 138 wheels
It's been ridiculous cold here in Montreal the entire month of January. My 04 545 had minor cooling system issues early Jan along with unstable interior heating. Replaced the water pump, thermostat, new coolant, reservoir/cap, serp belt/tensioner plus ALL hose clamps. I should have done this maintenance before winter, but I just bought the car the end of November. Other than that, I've had no driveability issues if I let the engine warm up properly.
Quick Reply: Cold weather effecting my 545i in a bad way
