I noticed this last year but it came and went. I have my car in a garage but as the weather is now getting much, much colder when I leave the car sit for a long time and get back in to start the brake pedal is stiff as a board. As soon as I turn the car on it goes back to normal.
What the hell is it? Seems to me like it is a warning of something to come that I should have fixed. |
I think I found the answer via Google from a 3 series forum....
SI B34 06 07 Brakes November 2007 Technical Service SUBJECT Additional Effort Required to Press Brake Pedal Prior to Engine Initial Start MODEL E90, E91, E92, E93 (3 Series) produced up to 9/07 SITUATION A customer may report increased brake pedal effort prior to engine start. This situation can occur if the vehicle sits for extended periods of time. Although the brake pedal can be depressed, the customer may note a change in pedal feel. CAUSE The vacuum check valve, fitted at the brake booster, may leak due to component tolerances within the valve assembly. CORRECTION Replace the vacuum valve and hose assembly for the brake booster; refer to Repair Instruction RA 34 33 051. PARTS INFORMATION Part Number Description Quantity 34 33 7 577 336 Vacuum Pipe 1 WARRANTY INFORMATION Covered under the terms of the BMW New Vehicle Limited Warranty. Please refer to the latest KSD for all applicable labor operations and allowances. If the appropriate labor operation is not contained in KSD, then a work time labor operation should be used. Defect Code 34 33 00 14 00 http://www.bmwtis.com/tsb/bulletins/...p/B340607g.htm |
