Cold air from pass side vents only while on heat mode
Old 10-11-2011, 01:12 AM
SilberGrauE60's Avatar
Originally Posted by seanjordan
Is the rear vents set to hot/cold? You can control the rear air temp from the rear.
We have a rear seat?!?
Old 10-11-2011, 05:10 AM
seanjordan's Avatar
My Ride: 05 BMW 530I
Of course! Its the space behind you that never gets used.
Old 10-11-2011, 08:46 AM
Gilgorm's Avatar
My Ride: 2012 535i X-driveSpace Grey/Black Dakota, Fineline Anthracite Trim; Executive Package (Rear View, Lumbar, Nav, Voice, SIRIUS, HiFi Pro) Technology Package (Hi Beam Assist, Lane Departure, Blind Spot Detection, Surround View) BMW Apps (Apps, Smart Pho
Model Year: 2012
Originally Posted by howorks
Your pic shows that you will get lots of airflow through the centre vent BUT it will be cold. The bars on the left only indicate flow not temp.
Just to the right, the two BLUE bars indicate cold. There are four BLUE (cold), one WHITE(neutral) and four RED(hot) bars in total. Using the iDrive knob, first toggle to the spot then turn the iDrive knob to your desired temp. For hot days you need four BLUE(cold) bars and for very cold winter days you need four RED(hot) bars. I change these quite often. BTW, if you press the centre climate control button to Auto your settings for the vents in the pic are not used but the temp is still active. Just press the centre vent button once to change the temp easily. Also temp changes only occur for the centre vents. The other vent temps are controlled by each knob with the temps on them.
ETNav382
04-24-2015 07:29 PM
zippers525
04-16-2004 11:01 AM
08-12-2003 11:41 AM
reckamech
07-22-2003 12:33 AM
06-17-2003 09:38 PM
Quick Reply: Cold air from pass side vents only while on heat mode
