Coilover and lowering springs..
Old Jun 21, 2009 | 05:41 AM
tim00001's Avatar
I am still new at these stuffs but can someone educate me on this topic.
I have eibach lowering springs on my 535I and I want to be able to adjust my heights so I figure coilover is the only way to go. If I buy a set of coilovers, can I change my eibach springs into the coilover?? I don't want to waste my eibach springs after I buy the coilover. I am sorry if this is a stupid questions..
Old Jun 21, 2009 | 05:45 AM
Alpine White Girl's Avatar
a lot of people are going to say search it.
i dont know much about suspensions but what im going to say is there is no chance your eibach springs are going to be converted into coilovers. coilovers are completely different. If you want to adjust your height then your going to need coilovers. You should try and sell your eibach springs and then move onto the coilovers.
Old Jun 21, 2009 | 05:49 AM
08white's Avatar
My Ride: 2008 BMW 535XI white
if you get coilover, then you dont need your eibach spring
if you want to keep the eibach spring, then get shock only
but i believe most people will see spring and get coilover
Old Jun 21, 2009 | 09:58 AM
not a stupid question no worries. +1 coilovers will replace the whole spring and shock setup. if you decide on coilovers, you can try selling your eibach springs. or like said above, you can go aftermarket shocks to complement the springs. personally Im running on bilstein sport shocks with my eibach pro-kits. the height wont be adjustable though.
Old Jun 21, 2009 | 10:01 AM
skelevirus's Avatar
Model Year: 2019
word get coilovers if you got the $, ditch the eibachs
Old Jun 21, 2009 | 03:47 PM
acuteperformance's Avatar
My Ride: 14 550i
hi tim,
if you want to adj height you'll have to get rid of your springs and either (1) buy coilovers or (2) get springs that lower the car more.
option 1 is going to be a lot more expensive ($1500-$2000) but well worth it because you'll buy a system that has been built and designed with all components working together. plus, you'll be able to adjust height from ~0.5" - ~2.5" and adjust dampness (softer or harder ride experience).
option2 is going to be the less expensive method (~$300) but without changing the oem shocks you risk blowing them in the future and needing to purchase new ones (~$700). also, there is the possible that because the springs aren't made for your oem shocks you'll get a very uncomfortable ride and trimming your bump stops.
bump stops are what prevent your car from bottoming out and damaging your suspension. they are normally made out of a foam/plastic material so it's not terribly difficult to trim.
hope i answering your question and didn't confuse you with more info.
let me know,
michael
acute performance
Old Jun 21, 2009 | 04:39 PM
tim00001's Avatar
Originally Posted by myfootsmells' post='919274' date='Jun 21 2009, 06:47 PM
hi tim,
let me know,
Thank you for all your wonderful lesson. What kind of coilover should I get??? I see some on ebay and I see some on myhotbimmer.com ?? can you recommand any brand??
michael
acute performance
Old Jun 21, 2009 | 04:40 PM
My Ride: 14 550i
Well I personally sell CROSS Suspension coilovers you can check out here: http://forums.e60.net/index.php?showtopic=79204
I personally have them on my car and love them.
Michael
Acute Performance
Old May 7, 2010 | 09:42 AM
ModBargains II's Avatar
Most coilover kits come with matched springs and dampers with a threaded adjustable spring perch. The coilovers also can feature damping adjustments to get the most out of your suspension in a variety of settings.
The Eibach spring will not work too well with coilover shock that was designed to work with the coilover springs.
We can get you great deals on KW, H&R, Eibach, and many other brands if you're leaning towards making the change.
Old May 7, 2010 | 10:21 AM
redEYEjedi's Avatar
Great options. I wonder what the OP decided on 1 year later..
