coil+sparks before valve job - 5Series.net - Forums
Sponsored by:
Sponsored by:
Thread Tools Search this Thread
Old 05-18-2018, 08:44 PM   #1
My Ride: 2005 545i 6-speed
Model Year: 2005
Default coil+sparks before valve job
Hey guys,
is it ok if i replace my coils and plugs before i do the valve gaskets? i m not comfortable doing the gasket on my own so i m waiting for a quote from a couple of indies near me....
thanks!
t_mo_t is offline   Reply With Quote
Old 05-23-2018, 07:44 PM   #2
Model Year: 2005
no one?
Old 05-24-2018, 05:30 PM   #3
My Ride: 535xi
I'll offer the thought that switching out the plugs and coils requires a lot of disassembly that you'd have to pay somebody to duplicate for the valve cover work. So, if you're not comfortable doing the VC R&R yourself, it would make more sense to pay somebody to do it all. I can't imagine it would cost you any extra since the plugs and coils have to come out to change the gasket(s). This assumes the mechanic would be OK with you suppying the plugs and coils if you're worried about his markup on those parts.
audiophool is offline   Reply With Quote
Old 05-24-2018, 06:56 PM   #4
Model Year: 2005
Hey,
Oh sorry, i forgot to mention that i got a misfire on cyl6, so.... i thought i would just replace all coils and sparks on the driver side first... but then again, since i got oil leak from the gasket (my indy told me this), would the oil be leaking into the ignition coils?
Old 05-25-2018, 05:39 AM   #5
My Ride: 535xi
Oil leaks can be as little as minor seepage for some techs to suggest replacement. Oil leaking into a spark plug well will defintely cause issues with spark if it gets bad. I had oil in one plug well and no misfire, so it likely would be leaking a fair bit to cause a problem. Still, all the underhood bits at the back of the engine bay need to come off to get the VCs off, so my original thought still applies.
Old 05-25-2018, 06:52 AM   #6
Model Year: 2005
Hey Audiophool,
Yeah, i;ve been watching some youtube (esp from shop4life) regarding the VC gasket replacement (his was on 550 but it is the same engine as 545 right?)
Yes, so... my tech said the leak was coming out from the gasket after he cleaned up everything and i went back there a week later... i just want to solve the misfire issue first since my car is driving quite rough.. and i m hoping it is just the coil that needs to be replaced.
Old 05-26-2018, 08:32 AM   #7
My Ride: 535xi
Well if you want to dig in and replace the coil/plugs to chase your misfire that's a fine idea. Just that when you do get the VC gaskets done, somebody else will need to re-do most of the labour. Your car, your call.
Old 05-30-2018, 07:09 PM   #8
Model Year: 2005
Thread Thread Starter Forum Replies Last Post
Help! 2008 550i won't turn over by hand (botched valve stem seal job) insightbrewery E60 Discussion 2 02-22-2018 06:22 PM
No start after valve cover coil and plug replacement Gee_115 E60 Discussion 5 02-28-2017 01:00 PM
535xi valve cover job docbubba1 E60 Discussion 8 03-08-2016 04:56 AM
m54 valve cover gasket job Bill109 E60 Discussion 4 02-09-2015 02:03 PM
so before you complain that your job sucks... daydok Lounge 17 08-07-2005 10:16 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
All content Copyright 2012 by Internet Brands, Inc.
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
